Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek 1.7 or 2.1
Old Dec 18, 2009 | 05:42 PM
JABrx7's Avatar
1.7 or 2.1
i have a 88 T2 with a bnr stage 2 s5 trubo and a street ported engine. I was wondering if i could go with the 1.7 and use the 750 cc secondary and be able to up the boost a little or if it would be better to go with the 2.1?
Old Dec 18, 2009 | 05:56 PM
drifting in drifting's Avatar
2.1 without a second thought
Old Dec 18, 2009 | 06:03 PM
Nick_d_TII's Avatar
You can do whatever you want.. Aftermarket turbo, and aftermarket fuel setup I'd go with something that is 'tunable' (as I have). 1.7 would probably be ok, but 2.1 would allow you to KNOW its ok. Or at least have a better Idea whats going on.
Or, go with 1.7 and cross your fingers, but if it goes lean under heavy boost(+10psi), your going to be getting a buying and installing a new set of apex seals possibly.
With 2.1 you can richen it up then pull fuel and adjust the timing too (do some actual tuning).
Almost everyone here will probably tell you 2.1... but it's your money and your car... What do you feel safe running?
Shameless thread plug - https://www.rx7club.com/rtek-forum-168/afr-tuning-methods-827389/
Old Dec 19, 2009 | 12:00 AM
JABrx7's Avatar
how hard is it to tune it your self also. if i was to go the 1.7 rout would i be fine if i didnt go above 10+?
Old Jan 25, 2010 | 04:06 AM
JABrx7's Avatar
would this aem wide band be able to work with the rtek even though it doesn't have a gauge ? http://www.aemelectronics.com/index.php?cPath=15_36
Old Jan 25, 2010 | 01:05 PM
Nick_d_TII's Avatar
I'm running a PLX SMAFR w/o a gauge and logging it on the palm. as long as it has a 0-5v output you should be able to log it and view it correctly. It sounds like its exactly what you want, but check out PLX, it has worked for me...
Old Jan 25, 2010 | 01:37 PM
Omixeo's Avatar
'89 GTUs
Yes that will work.
Old Jan 26, 2010 | 10:56 PM
JABrx7's Avatar
well looking over everything i think i will go with the 2.1 but one last question how hard is it to tune with it?
Old Jan 27, 2010 | 11:38 AM
Nick_d_TII's Avatar
Dude, you have to be a rocket scientist to figure it out. Like, it's not for little girls. I could barely figure out how to get in my car let alone plug in the ecu and turn the key.
No, wait, you have to be a nuclear scientist.
Really, its not that hard, unless you can't tie your shoes... Then I dunno...
https://www.rx7club.com/showthread.php?t=827389
Old Jan 28, 2010 | 03:21 AM
JABrx7's Avatar
thanks for all the help i will probably get one here soon and start messing with it.
smikels
Rtek Forum
May 12, 2016 12:34 AM
R.O.D
34
Jan 6, 2016 12:09 AM
tidanb0utch
11
Oct 7, 2015 07:36 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
Louis M
Nov 12, 2003 05:13 PM
