Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek 6 port na turbo using rtec as management
Old Dec 17, 2009 | 03:45 PM
frkydkyrednek's Avatar
VA 6 port na turbo using rtec as management
I heard a rumor awhile back that if i was to switch my vacum sensor with a t2 boost sensor and the na afm with a t2 afm, i could use rtek to tune for boosting an 86 gxl for boost. I was just wanting some input on this topic
Old Dec 17, 2009 | 11:50 PM
3rd and final 7's Avatar
wheres the water goin?
im using a a rtek 1.5 on my 6port turbo. im using t2 boost sensor , afm , injectors and i got an AEM raising rate FPR. everything runs great i retarded the timing abit an i boost nice up to 8-10 psi
Old Dec 18, 2009 | 10:09 AM
turbo2ltr's Avatar
The MAP, AFM and ECU should all match. i.e. don't mix a turbo ECU with one or both NA sensors or vice versa.
Old Dec 18, 2009 | 04:14 PM
sorry let me clearify myself i am running all turbo components including the rtek 1.5 ecu, injectors, afm, boot sensor
Old Dec 20, 2009 | 07:26 PM
k cool thanx guys. also (3rd and final7) what comp are you running 9.4 or 9.7. I have a S4 car with a S5 block we modified the lower intake manifold to fit the the S4 middle and upper intake. i'm already running t2 secondary injectors and pump would i really need to run the t2 primary's as well
Old Dec 21, 2009 | 01:04 AM
im running this in my 84 SE and im running a 88 6port so its 9.4 . i took the tii intake mani and ported to fit the 6 port block. i would get tii primarys at least also!
oh yeah im also running a walbro 255
Old Dec 21, 2009 | 06:30 AM
Buggy's Avatar
I've Been Wankeled!
If you run the rtek 2.1 you have selectable injector choices. Just for fun I hooked my 2.1 up to my 6 port NA. I used a TII map and AFM and it fired up just fine. It wouldn't idle but I figured that much. I just wanted to confirm that the ecu was working.
Old Feb 12, 2010 | 02:51 AM
NoPistons!'s Avatar
Tango Down
I have an rtek 6 port tuning question.
You can mess with timing and plug in your injector size. Could you run a slightly larger injector than what you programed in and keep the base timing for those injector sizes but bump fuel up via safc to compensate for higher compression?
I was planning on building my entire system around an rtek, 550/680, safc, wideband, egt, and boost gauges PRIOR to boosting. I also WILL run aux injection. I want my car to be fun, easily tunable and most of all, SUPER RELIABLE as it will see track time once or twice a month as well as get me back and forth to work.
I was going to do an engine swap (non rotary) for reliability reasons but proper tuning, common sense and proper care can help a turbo rotary go a long way.....and i'm getting a backup car/daily.
I'm hoping to get some answers/insight/questions on my system.
I haven't decided what turbo setup i want to run yet but the cheap bastard in me says oem kouki turbo and manifold.
Edit: My power goals for any car is 250-350 power range. I can't get that with a stock turbo but i'm hoping rtek and the safc/meth can support it down the line?
Old Feb 12, 2010 | 10:11 AM
arghx's Avatar
rotorhead
if you plan to get a 2.1 , why would you use an SAFC ? there's no point...
Old Feb 13, 2010 | 05:00 PM
NoPistons!'s Avatar
Tango Down
Because it looks cool.
Nah, i kid. Could just run a 1:1 fpr or adjustable fpr.....
Old Feb 13, 2010 | 09:33 PM
arghx's Avatar
rotorhead
you can adjust the variable resistor function (if you are s4) to lean out the idle. During normal cruising the O2 sensor will help lean out the mixture. Under WOT you can use the Rtek's fuel maps to make whatever adjustments are necessary.
The SAFC is just going to confuse the engine load readings to the Rtek.
Old Feb 25, 2010 | 04:10 AM
NoPistons!'s Avatar
Tango Down
That's what i figured. I guess people were using rtek and an safc with the earlier/base versions of the rtek system.
2.0 is what i'll go with. How would i squeeze more fuel out of injectors larger than the rtek selects? Say if i wanted to run 550-1000 or 550-850.....?
Old Feb 25, 2010 | 07:48 AM
arghx's Avatar
rotorhead
you would select 550/720 and then you may actually have to lean it out.
Old Feb 28, 2010 | 11:14 PM
NoPistons!'s Avatar
Tango Down
Alright!!!!!!
Thank you.
I was a bit worried i wouldn't be able to support 300-350hp on one of these if i so choose.
sherff
Feb 24, 2019 12:09 PM
hotshot2014
Jul 18, 2017 02:30 PM
Engine stand ready
Aug 14, 2015 10:26 PM
