Overspray on Hatch Glass
Would it be OK to wet sand it down? I know it will be, but I do not know which grit to start. I would like to go with 1500 then 2000, but do not want to leave any fine scratches.
Ewww, I wouldn't sand it, might scratch. Steel wool or the plastic scotch scrubbies are OK, combined with a little paint thinner to loosen up the paint. Or just use a single edge razor blade and holder, that should take it right off.
+1 for razor blade or paint scraper tool; always the best way to remove paint from smooth glass. Sandpaper can cut into glass. Solvents work fine too. Keep all of 'em away from the bottom-edge trim, though.
Trending Topics
On glass I have always used lacquer thinner, it literally takes just several minutes to clean up overspray. Lacquer on glass is just fine, however lacquer on plastics or other permanant painted surfaces is not good.
