Buying an 86, but car doesnt run.*Please Read**
Old Dec 13, 2009 | 08:27 PM
hachiidori's Avatar
Question Buying an 86, but car doesnt run.*Please Read**
Im looking at an FC for 700. It doesn't run and recently died on the guy. Im posting here for some guidance as to what to expect to fix. I talked to the guy and this is what he said,
"Driving down the freeway, the car started to sputter and would cut out then pick back up. Then lost all throttle response. As of now, all it does is fire up, then dies, tried starting fluid once and it ran fine. Replaced fuel pump and filter and MAF, checked circuit opening relay and main relay, all seem fine. Has spark just not getting fuel. Not sure what's wrong."
If the engine isnt getting fuel, that would mean something may be wrong with the ecu?
Old Dec 14, 2009 | 09:22 AM
Aaron Cake's Avatar
Engine, Not Motor
It could be a lot of things.
I would still consider the AFM or associated wiring to be an issue. The pins can get damaged in the harness and will cause the symptoms described.
Injector resistors could be another cause.
A stuck injector can cause this.
Old Dec 14, 2009 | 11:37 AM
hachiidori's Avatar
i see. if it had happened to you, what would you first check or change?
since he said theres spark but no fuel, should i lean more towards electrical??
Old Dec 15, 2009 | 02:17 AM
hachiidori's Avatar
anyone? Seeking some wisdom and want to learn.
Old Dec 15, 2009 | 08:50 AM
Aaron Cake's Avatar
Engine, Not Motor
I would check what I suggested.
Have someone crank the engine while you listen to the primary injectors with a stethoscope.
Old Dec 15, 2009 | 01:59 PM
hachiidori's Avatar
Ok. Thanks for the guidance. I will do what you said first then come back.
time to see why this rotary is dead. :]
*close*
astrum
24
Nov 15, 2017 08:44 AM
FDNewbie
161
Sep 6, 2015 11:10 AM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
cam_7779
Aug 18, 2015 07:48 AM
