Rotary Drag Racing The place to post your racing stories and info
lower engine containment/engine diaper
Old Dec 12, 2009 | 02:59 PM
mazda rx2 rotary's Avatar
Now that my rx2 has gone 9.72@134 tech has told me that I need a engine diaper!does anybody make one for a FD engine/GSL-SE oil pan?the best 1/8 mile is a 6.06@111!best 60 foot is a 1.27 this POS gets out of the hole hard Ujay has a video I will try and link the video, in the same video an R100 clipped the wall easy fix and he will be running again
Old Dec 12, 2009 | 05:42 PM
ultimatejay's Avatar
I don't know about engine diapers. The tech must be thinking about v8's. I think you need a steel scatter shield made out of 1/4" steel for the flywheel/clutch and for the engine, I think running that fast you need a oil catch pan under the engine in case you motor blows to help catch the oil from spilling on the track. You can fabricate this out of alluminum sheet. The specs should be in the NHRA rulebook. Call Rene, he has one on both of his cars.
Old Dec 13, 2009 | 03:31 AM
K1HKSarse's Avatar
United Kingdom
congrats on the 9.7 dude, well done. Lots more to come though i suspect????
Old Dec 13, 2009 | 04:29 AM
sen2two's Avatar
Rx2 > FD
an engine diaper is simply a cloth like material that goes on the oil pan. for when rods and pistons blow out the bottom of the block. the tech at the track dosnt know **** about rotarys. diapers are not needed on rotarys for the obvious reasons...
theres a 1/8 mile track here in Orlando that its a must for almost all rotarys to run them. So stupid...
Old Dec 13, 2009 | 10:42 AM
sk8world's Avatar
Chasing numbers
Get one of Erik's (Viking's) dipers.. Anything that will fit his 300lb *** should go over your motor just fine... LOL.....
Old Dec 14, 2009 | 01:45 PM
Gohan3rdrift's Avatar
Movie Star
AWWW Snapp!!!!
Old Dec 14, 2009 | 03:30 PM
zinx's Avatar
_________________________
How often does a rotary oil the track down from the engine itself? I'm guessing its pretty rare.
Old Dec 14, 2009 | 03:59 PM
sk8world's Avatar
Chasing numbers
Originally Posted by Gohan3rdrift
AWWW Snapp!!!!
He must be hibernating......
Old Dec 14, 2009 | 05:34 PM
sen2two's Avatar
Rx2 > FD
well, here in Orlando, its ALL THE TIME! cause the rotary people here are cheap *******. Rotarys have such a bad reputation here its insane. i cant mention i drive an Rx7 without someone mentioning how much they break or oil down tracks.
To many people saying there uncle in PR has a 9 second something with junkyard parts in it. so they try it and give us the bad name...
Old Dec 14, 2009 | 06:03 PM
Honda's take the cake when it comes down to oil downs and axle/trans breaks.
Old Dec 15, 2009 | 12:48 AM
61620B's Avatar
I use a pan with folded edges about 1 3/4.....i made mine of aluminum and it really works good.Had some oil and water and a bunch of stuff with just a pan.If not cal DJ safety or
DEIST(local socal shops),they have some really cool engine diapers for v8's.They custom make good stuff.
C. Ludwig
Jan 30, 2019 06:31 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
