Microtech What efan to run?
Old Dec 11, 2009 | 12:35 AM
hurleysurf24's Avatar
wtf rotary wtf
What efan to run?
What works best/most controllable with the lt10s?
Old Dec 11, 2009 | 02:56 AM
SmogSUX's Avatar
No money. No love.
I have the flex a lite black magic fan...the temp control switch on it SUCKS....Mines failed multiple times and blows fuses like there's no tomorrow. My buddy went through 3....thankfully flex a lite sent him new ones. Once I have the money I'll pay Karack to wire mine through my LT8s..he said it shouldn't be too hard.
Old Dec 11, 2009 | 01:35 PM
hondahater's Avatar
spending too much money..
I've used the ford fierroGT fan and it was perfect. It fit the fc radiator perfectly and cooled just as well as the stock fan. The fan motor started making noises when it would turn on so I ended up taking it off and going to aaron cakes website and he recomended a fan from an old 86 oldsmobile. I've had that on my car for a while now and while the fitment isn't perfect like the fierro fan it still cools just as well as the fierro fan.
Old Dec 11, 2009 | 01:40 PM
wtf rotary wtf
how would one wire it up to function through the microtech?
Old Dec 11, 2009 | 05:35 PM
hondahater's Avatar
Easy cheesy. look at this diagram and just change out the water injection pump for the efan and instead of using the white wire for the microtech you will use the white/red.
https://www.rx7club.com/attachment.p...2&d=1259257232
edit: only other thing you can do is come down from pin 86 with a wire to an on/off switch just incase for some reason the microtech stops working.
Then you just have to go to the fan_on (I believe is what it's called) in the microtech and set what degrees it comes on. I have it set to 86 others set it to 88-90.
Old Dec 13, 2009 | 04:41 PM
wtf rotary wtf
i assume that led indicator is just a feel good "fyi" for inside the cabin?
Old Dec 13, 2009 | 05:01 PM
rx72c's Avatar
Top Answer: 1
lol.
Get your self a Spal 3000CFM fan.
BEST FAN PERIOD..
Next wiring it up is easy.
Get 2 40 amp 4 pin relays.
Wire pin 87 of each relay with a seperate 6.5mm wire straight to the battery.
Send pin 30 off each relay both with a 6.5mm wire straight to the fan and then join them into one at the fan.
Pin 85 off both relays goes to the white/red wire on lt10s. And pin 86 on both relays goes to ignition.AND YOU ARE DONE.
Old Dec 13, 2009 | 06:24 PM
hondahater's Avatar
So dumb question but what's the deal with having 2 relays? I'm assuming just incase one dies?
Old Dec 13, 2009 | 08:49 PM
rx72c's Avatar
Top Answer: 1
No its not a safety feature.
I have found even though spal say their fan draws 28 amps.
I have one 40amp relay gets very very hot so i changed it to two and they both run cool so i figured one relay wasnt enough. Id rather everything ran 100% then close to border line.
This where theory and actual practice do not meet.
Old Dec 17, 2009 | 01:21 AM
RotaryEvolution's Avatar
Sharp Claws
run dual relays in paralell, 2 relays should be able to split the load fairly well without much worry about burning out. be sure to use heavy duty relays, 20+ amps if possible. i do wish 40 amp relays were easier to get locally. overkill is better than having one melt at an inopportune time and in this case bigger is better.
the black magic can easily pull close to that when it kicks on, smaller fans will pull less amperage but that black magic can just about pull the car along with how many CFMs it pulls.
Old Dec 22, 2009 | 11:12 PM
wtf rotary wtf
Originally Posted by rx72c
lol.
BEST FAN PERIOD..
anywhere specifically on ignition?
Old Dec 23, 2009 | 03:56 AM
rx72c's Avatar
Top Answer: 1
Every car i wire up i run a 6.5mm wire from barrel and share that with all my relays and ecu etc.
Old Dec 26, 2009 | 12:58 PM
wtf rotary wtf
rx .. did you get my pm ?
Old Dec 26, 2009 | 04:46 PM
rx72c's Avatar
Top Answer: 1
I dont think so. Can you send it again/
Old Dec 26, 2009 | 05:15 PM
wtf rotary wtf
just asking if you could throw me a map for my current setup:
3mm rotors, pinned/balanced/clearanced, Greddy FMIC, stock injectors, Warlboro 255, large streetport, hybrid turbo (larger turbine), 3" full exhaust. Using the LT10s with X4 box and igniters.
Stuff that probably doesnt matter; brand new housings, brand new rotors, 90% of the engine has been powder coated.
btw; im going to scrap the blackmagic ... not flowing enough. going taurus efan.
Old Dec 29, 2009 | 12:38 AM
rx72c's Avatar
Top Answer: 1
You bought brand new rotors and made them 3mm? I could cry
Old Dec 29, 2009 | 10:51 AM
wtf rotary wtf
i didnt pay full price they cost me 700 bucks for both.
Old Jan 6, 2010 | 02:23 PM
Sharp Claws
the black magic isn't flowing enough for a small(ish) hybrid turbo? something is wrong there..
Old Jan 6, 2010 | 03:04 PM
wtf rotary wtf
at idle
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
The Shaolin
Sep 14, 2015 07:50 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
