My tach is acting crazy
Old Dec 9, 2009 | 04:18 PM
jim.mul's Avatar
After installing new distributor, cap, rotor,wires, getting the dwell and timing and wires right, my 79 runs much better than it did if I increase throttle gradually. If I stomp the pedal, the tach goes to zero, then fluctuates wildly while the engine bucks and stutters. Since I learned from a thread that the tac is hooked to the trailing coil, I assume I screwed something up, and my problem is something electrical in that area. Any ideas?
Old Dec 15, 2009 | 02:39 PM
jim.mul's Avatar
We can scratch this thread, or end it here. Found wiring diagrams on fox.ca , cleaned term inals on short relay and coil resistors. Runs well now. Tack is normal
Casual_John
Canadian Forum
Sep 26, 2015 01:47 PM
subeone
Sep 24, 2015 09:58 PM
