bumpy ride on the highway!
Old Dec 9, 2009 | 02:53 PM
debusta05's Avatar
everytime im on the highway, even if im going round 60-70 or more the car starts shaking and the ride starts getting bumpy, so i was thinking it might be the tire rods since it was shaking so bad, or suspension but i dont really think so.
Any help id appreciate it
Old Dec 9, 2009 | 03:54 PM
gracer7-rx7's Avatar
needs more track time
Sounds like your tires might need to be balanced.
What car do you have? Is it stock?
This place is somewhat nearby you if you need a rotary specialist to check out the car http://www.pfsupercars.com/
Old Dec 10, 2009 | 09:10 AM
debusta05's Avatar
mkay ill look into it, but other than tires, is there anything that could cause that? and its a 1989 GTU non turbo convertible
Old Dec 10, 2009 | 11:15 AM
Doubtful. Its definitely not the tie rods.
What rims, tires and suspension are on the car?
Old Dec 12, 2009 | 08:47 PM
Tidfu's Avatar
have you checked your tires? my DD did this and all it needed was balancing, took it to a tire shop and boom no more vibration.
Old Dec 13, 2009 | 09:43 AM
Dunnfords's Avatar
Deffinately a balancing problem..
have you hit any major pot holes? could be a buckle that you wouldnt really notice at lower speeds..
Old Dec 13, 2009 | 10:25 AM
debusta05's Avatar
well the suspension and rims are stock, but the tires are toyo i believe, and yea i think its a balancing problem because even if its low speed, it still bumps so
Old Dec 13, 2009 | 11:18 AM
Dunnfords's Avatar
it would be more than worth it to take it to the tyre place (EDIT: That you got them fitted) and give these symptomns to them, theyll soon sort you out, and for free i should hope!
Old Dec 13, 2009 | 01:47 PM
bewtew's Avatar
1BAD20B
sounds like a balancing problem or could be a bent wheel. Take it to a tire shop and have them check it out..
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
LongDuck
Oct 7, 2015 08:12 PM
Jmpabon93
Sep 30, 2015 04:57 PM
Ernstudet22
Sep 14, 2015 09:19 PM
