Please help!!!!!! Car doesn't start
Old Dec 8, 2009 | 01:27 AM
NORCAL88FC3S's Avatar
Just put in a new motor that had been rebuilt 20k miles ago, compression is great, but the motor doesn't fire up, turns over like it was flooded but still doesn't fire after going through the unflooding procedures. Is there anybody out there whose had the same issues? Could the timing be causing it to do that? Please help I really don't wanna pay the mazda dealership 125.00 dollars just to look at it if it's something I can do myself. Any sugestions would be great!!
Old Dec 8, 2009 | 08:54 AM
Aaron Cake's Avatar
Engine, Not Motor
This is an RX-7 I assume? What year?
Old Dec 8, 2009 | 03:19 PM
yeah it's an 88 fc gxl
Old Dec 8, 2009 | 03:34 PM
irishpilot's Avatar
are you getting spark?
do you smell fuel?
Old Dec 8, 2009 | 05:56 PM
BennybamFC's Avatar
Mr. Rotary Power
double check the wiring
Old Dec 8, 2009 | 06:48 PM
GST7's Avatar
STANCE IS THE KEY
are you getting fuel??? make sure the fuel lines are correct..
how do you know its flooded???
Old Dec 8, 2009 | 07:42 PM
Is there any way to check the spark with out an ohmeter? Sorry if that's a dumb question I'm a noob to the car scene. And I didn't know if it was flooded or not but I thought i'd check since my last motor would flood all the time and it would do the same thing crank over but not start
Old Dec 9, 2009 | 09:17 AM
jmax's Avatar
My RX7 doesn't run yet!!
man, sounds like my case... I tracked it down to a 'no lead coil spark' issue and i'll have to track the wiring harness for pack rat damage...
Old Dec 9, 2009 | 02:13 PM
ok so i checked coils with an ohmeter everything checked out any ideas anybody what it might be?
Old Dec 10, 2009 | 09:02 AM
Aaron Cake's Avatar
Engine, Not Motor
So, are you getting fuel? Are the fuel lines on the correct way? Injectors plugged in correctly?
Have you checked for spark? Pull a leading plug wire, put it on a spare plug, place the plug on the shock tower so you can see it and crank the car. Spark?
What basic checks have you done and how did you check them?
Was this car sitting for a long time?
Old Dec 10, 2009 | 02:06 PM
enigmafc3s's Avatar
have you checked to make sure that the ground on the coil pack is good/connected?
Old Dec 10, 2009 | 02:42 PM
thanks for all the responses and help i apreciate it!
ive checked spark and everything checks out injectors are in right so are the fuel lines.
might just take it to the mazda dealership......
Old Dec 10, 2009 | 05:40 PM
Toxindude's Avatar
How do you know your getting fuel or getting flooded do you smell fuel?
What procedure are you using to unflood it the pulling the engine bay green fuse turning it over and replacing it?
Could this be a hot start problem I had a very similar problem like this long time a go engine had alot more miles on it though?
Old Dec 12, 2009 | 01:54 AM
taz4u2nv's Avatar
good luck with this,ive been keeping an eye on posts like this in hope that id find a solution to my problem which is quite similar to this,...yyyyyyyyy?????
Old Dec 12, 2009 | 10:48 AM
Aaron Cake's Avatar
Engine, Not Motor
There is no coil pack ground other then the body of the ignitor. If it is bolted to the car, it is grounded.
So you are sure you are getting fuel into the engine?
When you crank the engine, can you hear the injectors clicking?
Is the CAS stabbed in the correct position?
Are you ABSOLUTELY SURE the fuel lines are not backwards? The line from the filter should go to the pulsation damper, the line from the pressure regulator should return back to the tank.
Do you have any larger air leaks?
AFM plugged in?
Old Dec 12, 2009 | 08:54 PM
Tidfu's Avatar
like everyone said check spark, fuel, and also see if its grounded correctly
Old Dec 14, 2009 | 06:19 PM
Update.....
I've gone ahead and taken the car to the mazda techs and they're saying there's no spark. They don't know why there isn't any it's been two days since I took it to them anybody got any ideas?
Old Dec 15, 2009 | 07:12 PM
Toxindude's Avatar
You would think that if they told you there was no spark they would know why if they looked it over. There could be any number of reasons you have no spark. Bad coil packs? Bad wires? Battery? Is the engine start fuse in the fuse box in the engine bay? I am sure there may be other reasons I can't think of atm ANYONE ELSE?
Old Dec 29, 2009 | 01:49 AM
*******Update******
It turns out it was the MAF sensor.
Old Dec 29, 2009 | 07:22 AM
SRT8's Avatar
*******Update******
How much did you pay for them to replace the MAF sensor?
Kyo
Apr 13, 2019 09:24 AM
smikels
Aug 18, 2015 01:26 PM
cam_7779
Aug 18, 2015 07:48 AM
