what's the easiest bolt on turbo upgrade/
Old Dec 6, 2009 | 03:54 AM
85spiky89T2's Avatar
Unhappy what's the easiest bolt on turbo upgrade/
hi all I have an 89T2 witha 91 T2 motor, it has an Apexi piggy back on the ecu , running Racingbeat 3" turboback complete exhaust (minus cats) with HKS intake, Now i want more boost, what is the easiest simplest bolt on turbine that I can purchase for more boost, or is there any turbine splines i can relace in stock housing than can produce more boost? i was told that i could keep the rear housing of stock turbo, swap front part with a bigger housing that will accomodate a bigger splined turbine but no one can produce part numbers or brands.Im already running quite rich so all i need to do is feed more air. can someone help me?
thx,Spiky
Old Dec 6, 2009 | 09:55 AM
Aaron Cake's Avatar
Engine, Not Motor
Take a look at the BNR hybrids.
You'll need upgraded injectors and fuel pump at the least. When you start to get into the higher stages (stage 3 and above) it is standalone territory.
Old Dec 6, 2009 | 03:57 PM
The CzAR's Avatar
Death or Glory
+1 for BNR
http://bnrturbos.com/2ndGen.htm will give you more information on the different stages, depending on what sort of fuel set up / numbers you're looking for.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
