Megasquirt Losing sync badly
Old Dec 1, 2009 | 09:39 PM
JonoT's Avatar
Losing sync badly
Hi guys been awhile since I last posted on here. Got my turbo fc working on ms2 with 2.1.0 code, however I have reall bad syncing issues! I have input settings as per Aaron cakes update (not settings in his write up) and have verified base timing at -5. I have modified the second vr conditioner as per Kens FAQ. Here is a picture of megalog viewer showing sync loss. It happens at idle but mostly at load.
Any help is greatl appreciated
Thanks guys
Oh i've also got shielded mic cable as well
Old Dec 2, 2009 | 09:08 AM
Aaron Cake's Avatar
Engine, Not Motor
That look slike a dropout of a VR signal.
Make sure the shielded cable is grounded at the ECU end only.
Check the condition of all the wiring, especially the CAS plug.
Old Dec 3, 2009 | 12:23 AM
muythaibxr's Avatar
MegaSquirt Mod
You will also want to make sure the ground configuration is correct for all other grounds. So the MS should be grounded to the engine, and the engine should be grounded to the chassis. All ground points should be nice and clean, and the battery grounds to the strut tower and the starter should also be clean and undamaged.
Finally, the 2nd trigger conditioner circuit should have a .01uF cap across G+ and G-, and should be set up in zero-crossing mode instead of with an RC timer circuit on pin 14 (just ground pin 14).
Ken
Captain Hook
13
Oct 4, 2015 06:35 PM
djessence
Oct 4, 2015 10:21 AM
