have issue with starting car
Old Nov 23, 2009 | 12:20 PM
badpescado's Avatar
anyone out there have a fix for my car not starting? I have a 90 gen 2 na. when i turn the key to start the car, it just clicks and nothing else. sometimes you have to the key 20 times before it will turn over? sometimes it starts on the first try? anyone know what could be the problem?
Old Nov 23, 2009 | 03:55 PM
hcutbirth@yahoo.com's Avatar
TX have issue with car starting
the most common cause of a click is a dirty bat cable at the bat, most common is the positve side. if the lights go out or dim when you try to start it then there is a really good chance that the cable is not well connected.
Old Nov 23, 2009 | 04:56 PM
Toxindude's Avatar
I had this problem once with my 86 like hcutbirth said check the bat cables connection clean them up nice should fix the problem start cheap and go from there.
Old Nov 23, 2009 | 06:16 PM
rotary_ftw's Avatar
it could be the battery cables like hcubirth said but if you clean cables up and it still doesnt work get your battery load tested.. if the battery should be at approx 12.7v before you load test and shouldnt drop below 10.5v when you load test... if the battery tests fine then go to the charging system your alternator should be puttin out approx 14.5vs when car is running anything below 13.5 alternator should be replaced
Old Nov 24, 2009 | 09:16 AM
kendark2light's Avatar
check the cables at your starter and trans to
Old Nov 24, 2009 | 11:51 AM
badpescado's Avatar
thanks everyone i will start there. but i am pretty sure that it is something more. my lights work fine as well as the radio. battery is less than one year old. but hey it wont hurt to get in there and do some routine maintenance.
Old Nov 27, 2009 | 08:02 PM
89X7's Avatar
Hi, I had a similar issue and it was pretty simple. Is it an automatic? If so, the next time it does it, leave the key on and move the shifter to neutral and then try to start. The switch in the shifter may be slightly out of adjustment. Hope that helps
alphawolff
Nov 17, 2015 05:57 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
torky007
Aug 17, 2015 05:14 PM
befarrer
Aug 14, 2015 04:18 PM
