Pulsation Damper
Old Jun 11, 2002 | 11:06 PM
88FCTII's Avatar
Newbie
Question Pulsation Damper
Hi All,
When I start my engine, I can smell a bit of fuel odor from the engine compartment, I've heard from people that the problem could be the pulsation damper.
How can I check whether or not the pulsation damper is working? would anyone have a step by step instruction on how to perform such checking?
Old Jun 11, 2002 | 11:21 PM
duboisr's Avatar
stop and find the leak, the fuel pul dam can be touched with out removing anything ,it has an exposed rubber tit you can feel . If it is soft or rubbery it is all right , if it is hard or broken off the fpd will need replacing .
Old Jun 11, 2002 | 11:30 PM
Icemark's Avatar
You should not smell fuel at any point under the hood unless something is disconnected or broken.
DO NOT DRIVE until the problem is fixed.
Old Jun 12, 2002 | 12:08 AM
rx7_turbo2's Avatar
Professor D.P
If it's a turbo I think it's bit harder to get at. Do a search on the forum for pulsation damper fix there should be lots of info. I just removed mine.
ls1swap
Jun 3, 2024 03:25 PM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
Steelwheelz
Sep 15, 2015 03:22 PM
