Alternator belt really loud?
Old Nov 22, 2009 | 01:33 AM
Oneiros's Avatar
Hey,
My alternator belt has been slipping badly, screeching real loud and stinking of burnt rubber... I ended up replacing it today, and it doesn't seem to be slipping any more, but instead there's a really loud whirring noise coming from the engine bay, anywhere over 2k revs. It's like a massive fan noise. Anyone know what this is?
Thanks
Old Nov 22, 2009 | 10:30 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the bearings on the alternator, water pump, and related driven accessories.
Old Nov 23, 2009 | 09:37 AM
Oneiros's Avatar
Hmm ok... I'm replacing the alternator as it's not putting out enough amps, if the problem persists I'll check the water pump. I'm suspicious about the fan though - it almost spins freely with the engine off, and I don't think it's meant to do this...
Old Nov 23, 2009 | 02:01 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Clutch fans are supposed to be able to free-wheel when the engine is cold. As hot air moves across the clutch assembly, it grabs and allows engine power to drive the fan.
Andrew7dg
Aug 6, 2017 01:41 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
Rbkouki
V-8 Powered RX-7's
Sep 29, 2015 08:54 PM
