fd startup help
Old Nov 20, 2009 | 12:20 PM
ckykid02's Avatar
Always Slideways
fd startup help
so my buddy, 240silvia on the forums, picked up an automatic fd on a trade for another car. supposedly the car was running a gm map sensor not the stock mazda one and the car was runnning in a "safe mode."
he picked up the oem map sensor and wired it in and the car ran fine for ten minutes or so. he shut it off and let it sit a few days and now the car wont start. we have listened and cant hear the fuel pump turn on with the key turned to on.
so he bought a new fuel pump and we installed it. still no difference.
any ideas? could he have wired in the map sensor wrong? apparently the car ran without the map sensor installed at all according to him
Old Nov 20, 2009 | 01:54 PM
The Spyder's Avatar
Never give up!
I know that car.
It had some jacked wiring. I can give you a hand, but not till I get back up there.
Old Nov 20, 2009 | 01:58 PM
ckykid02's Avatar
Always Slideways
when will you be back?
Old Nov 20, 2009 | 02:02 PM
ckykid02's Avatar
Always Slideways
oh btw i have the factory workshop manual and wiring diagram book for the 94 fd if it will help. it makes an akward clicking sound when switched to on position. dunno if thats normal i dont know much about fds. i havent really looked at the car too much since its been like pouring down rain lately
Old Nov 20, 2009 | 09:20 PM
zack4173's Avatar
I might be able to come look at it. where in tacoma are you located?
Old Nov 20, 2009 | 10:38 PM
ckykid02's Avatar
Always Slideways
it is located near 56th and pacific
Old Nov 21, 2009 | 12:17 AM
ncastrignano's Avatar
RE for life
if the fuel pump isn't humming check the EGI fuse on the positive battery termanal, chances are the car ran for a bit then something shorted when u turned it off and popped the fuse. so thats a good way to start.
Old Nov 21, 2009 | 06:47 AM
ckykid02's Avatar
Always Slideways
egi fuse is good and so is the relay
Old Nov 21, 2009 | 07:08 AM
mystikalbob's Avatar
Black Pearl
maybe it got flooded (fuel)???
Old Nov 21, 2009 | 02:41 PM
ckykid02's Avatar
Always Slideways
not flooded. pulled the egi cranked over for a while and put egi back in. no bueno
Old Nov 21, 2009 | 06:22 PM
Black Pearl
did you pull the spark plugs out while de-flooding it? cause cranking it over with the plugs in won't de-flood it. or maybe your plugs are fouled up.
Old Nov 21, 2009 | 07:05 PM
KompressorLOgic's Avatar
I
probably flooded
Old Nov 21, 2009 | 07:47 PM
I
check and see if the engine is throwing any codes, also check for spark, and if u replaced the fuel pump it problay has fuel...
Old Nov 21, 2009 | 11:12 PM
ckykid02's Avatar
Always Slideways
i only have an oem mazda fc and earlier code reader. lol it has spark. trust me. my fingers and my arm know for sure it has spark
Old Nov 22, 2009 | 01:20 PM
I
you dont need a code reader, u just jumper a wire in the engine bay and it will flash a moris code threw the check engine light. search for it, thats what i did to pull codes, i forgot which pins to jumper tho lol
Old Nov 22, 2009 | 01:23 PM
I
lol well heres the link i found it anyway http://www.fd3s.net/engine_codes.html all info on what codes mean how to pull em
Old Nov 22, 2009 | 03:44 PM
ckykid02's Avatar
Always Slideways
thanks man ill be trying this next time im over there
sherff
Feb 24, 2019 12:09 PM
SupraKiller
11
Jun 5, 2002 06:19 AM
JoelChicago
Mar 26, 2002 10:51 AM
whitekingsnake
11
Oct 19, 2001 05:09 PM
rxse7en
Sep 7, 2001 09:00 AM
