Quick BNR/Injector question
Old Nov 20, 2009 | 12:13 PM
barnett87rx7's Avatar
lite rotary = easy push
Hey guys im planning on a bnr stage four turbo upgrade and want to know if i go with 720's on all four injectors will that be sufficient or will I need to go bigger? im only shooting for 300-350hp
Old Nov 20, 2009 | 12:17 PM
stevensimon's Avatar
Yes
Old Nov 20, 2009 | 12:44 PM
arghx's Avatar
rotorhead
300? probably
350? probably not
Old Nov 20, 2009 | 01:01 PM
mikeric's Avatar
FB=OS Giken LSD
Really? Who is tuning your car? Ask them. Also, talk to Brian at BNR. He will tell you exactly what you need. If your tuner specifies something else, go with what your tuner wants. If you are doing the tuning, you should know what your fuel requirements are.
Old Nov 20, 2009 | 01:46 PM
KhanArtisT's Avatar
Former FC enthusiast
Originally Posted by arghx
300? probably
350? probably not
People with stage 1's have dyno'd around 300whp. With a stage 4 he shouldn't have a problem with 350whp+ given that he has a tuned standalone, according to what the BNR site says anyway.
Old Nov 20, 2009 | 02:39 PM
eage8's Avatar
1308ccs of awesome
If you're only shooting for 300-350 why are you getting a stage 4?
a bigger turbo isn't better, get one that's properly sized for your desired hp.
Old Nov 20, 2009 | 02:41 PM
getting a stage four for the future when i will be aiming for a higher hp and and have the funds to do so
Old Nov 20, 2009 | 03:29 PM
The CzAR's Avatar
Death or Glory
what are you using for fuel management?
Old Nov 20, 2009 | 04:12 PM
rtek 2.1
Old Nov 20, 2009 | 08:36 PM
misterstyx69's Avatar
Retired Moderator, RIP
Talk with BRYAN..I did..
he's a pretty knowledgeable guy...well maybe NOT pretty,,,haha!
Old Nov 22, 2009 | 11:18 AM
lonewolfrx's Avatar
a stage 1 bnr should be good to hit about 300hp..
Old Nov 22, 2009 | 11:27 AM
arghx's Avatar
rotorhead
I was referring to the 720/720 setup
Old Nov 22, 2009 | 03:12 PM
so 720/720 will be sufficient or should i go with 720/1600?
Old Nov 22, 2009 | 03:48 PM
arghx's Avatar
rotorhead
you can't do 1680's very well without a standalone that will give you more precise control over injector staging.
Old Nov 22, 2009 | 11:01 PM
younG_Gunner's Avatar
Re-Mama Mia!
I talked to Brian from BNR last week and I was told that 4x720's would be enough for a stage 2. Would it really be enough for a stage 4?
Old Nov 23, 2009 | 08:11 AM
arghx's Avatar
rotorhead
^ maybe if you cranked up the fuel pressure...
Old Nov 23, 2009 | 04:52 PM
Re-Mama Mia!
Possibly 5-10 psi?
Old Nov 26, 2009 | 10:13 PM
rx7 SE's Avatar
Enthusiast
what's a good site to pick up new injectors? kgparts?
Old Nov 27, 2009 | 10:36 PM
12AllWays's Avatar
It means 12A all ways^
720/1000 Good for 350hp
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
