whats the difference?
Old Nov 18, 2009 | 07:53 AM
joemaddox's Avatar
From: Philomath Oregon.The five whole blocks of it!
What is the difference between the S4 NA housings, S4 T2 housings and also with the S5 set ups?
Is it just the knock sensor holes and the defusers? What makes them different?
Old Nov 18, 2009 | 01:34 PM
KompressorLOgic's Avatar
I
S4 housings diff between na and turbo. difusser, and no coolent hole in housing ( the turbo ones have a hole like the 12a housings)
s5 housings diff are difussers, coolent hole, and knock sensor hole ( s4 has knock sensor on center iron.)
now diff between all s5 housings and s4 housings the spark plug locations are actually a little bit different which changes the timing!
Old Feb 1, 2010 | 06:18 PM
Biosci777's Avatar
So, what kind of problems, if any, could you expect if someone rebuilt an S5 engine, replacing the rear rotor housing with an S4 (Hiroshima)?
Old Feb 1, 2010 | 08:08 PM
The Spyder's Avatar
Never give up!
Bad timing. Misaligned sparkplug holes.
NA housings can be easily swapped to turbo. Drill out the coolant feed port and switch the difuser out.
Shainiac
Jul 17, 2019 02:20 PM
Spirit Rx-7
Mar 14, 2016 12:36 PM
Captain Hook
Sep 22, 2015 01:12 PM
Ian_D
Sep 6, 2015 10:38 PM
