Garret's new GTX-R billet turbos
Old Nov 16, 2009 | 09:38 PM
Trots*88TII-AE*'s Avatar
4th string e-armchair QB
I've found a bit of info on this new Garrett lineup, if anyone else has anything, post it up.
80% efficiency!
And some poor formatting of comparisons:
http://img694.imageshack.us/i/gtx4508r.jpg/
http://img696.imageshack.us/img696/1843/gtx4294r.jpg
All in all very promising stuff!
Old Nov 16, 2009 | 09:42 PM
Japan2LA's Avatar
sick...
Old Nov 16, 2009 | 09:54 PM
Blackadde///'s Avatar
20b GTX4294R MS Dry-Sump
release date?
Old Nov 16, 2009 | 10:00 PM
ByeByeSti's Avatar
god damn 108 mm is a big bastard haha. i second that, any news on the release date?? cuz i sure as hell havent seen these for sale yet
Old Nov 16, 2009 | 10:16 PM
Not sure. ATPTurbo has them advertised on their front page, which is where I caught it, but last week at SEMA. I'd say they won't be too long now.
Oh, and they apparently are releasing quite a few different models in re-designed Billet trim. Only thing that gets me wondering, is the new Garrett GTX 4294R, using a 94mm, 70mm inducer turbo is still putting out just shy of 100 lbs/min, and the PTE T3 6765 (84mm, 67mm inducer) turbo put down 920 AWHP on an evo, so I'd say it's putting out pretty near the same flow, but in a smaller package. I wish Precision would put out some damn compressor maps on their new ****, then we'd know for sure.
Old Nov 17, 2009 | 12:17 AM
thewird's Avatar
Nice, Garret finally joining the billet game. Wonder when they coming out with something a little smaller for us track road coarse guys .
thewird
Old Nov 17, 2009 | 01:17 AM
quattro4now's Avatar
thewird
I don't know about you, but a GTX3574R sounds like a winner (to me anyway).
Old Nov 17, 2009 | 01:38 AM
thewird's Avatar
Where was that listed? I only saw 42R's or higher in the to be released turbo's.
thewird
Old Nov 17, 2009 | 08:16 AM
Zero R's Avatar
Just in time to die
I was waiting to see how long before one of you guys posted this info The turbo's have a release date of december according to Garrett, but I will believe it when I see it. I know how they are and usually that means february. Then again who knows, they may have a few available by december as they are suggesting.
~S~
Old Nov 17, 2009 | 09:45 AM
How do you think the Precision line will stack up against them in terms of gain over cast Sean? I mean, on the 67mm billet wheel, AWDMotorsports made 920 awhp, that's gotta be in the 90-95 lbs/min range, no?
Old Nov 17, 2009 | 10:54 AM
ScorpionT's Avatar
I dont think theyre quite that high. They are probably in the 85lb/min area. They just make insane power because you can push the boost so high, which means higher efficiency.
I heard that Garrett will be releasing the 42R and 45R first, then others will come out shortly after. I sure do hope so! These are very promising, and will be good for people who want the reliability of Garrett but the performance of PTE billets.
I really wonder how the 11 full height blades will compare to the staggered style like PTE and FP have.
Old Nov 17, 2009 | 11:11 AM
Zero R's Avatar
Just in time to die
I think they will stack up just fine. They certainly have access to a larger budget if need be. I have a feeling you'll be seeing better gains on the smaller wheels than the larger ones, just a gut feeling. I think the one to be impressed with most currently is the 4294, the map is both taller and wider in some spots than the cast 4202.
Old Nov 17, 2009 | 12:33 PM
Originally Posted by Zero R
I think they will stack up just fine. They certainly have access to a larger budget if need be. I have a feeling you'll be seeing better gains on the smaller wheels than the larger ones, just a gut feeling. I think the one to be impressed with most currently is the 4294 the map is both taller and wider in some spots than the cast 4202.
I agree, that 4294 is pretty impressive. Even better would be in the 40R size, and you have yet another great street/strip turbo, with big power potential.
I agree about the smaller wheels, it makes sense. On larger wheels, you have less percentage of blade length to be gained by reducing the size of the shank compared to smaller turbos. There's an easy 15% more blade length to be gained on a 67mm cast wheel going to billet, but on a 108mm wheel, I'm sure it's proportionately less.
Old Nov 17, 2009 | 01:03 PM
Viper GTSR's Avatar
Performance Veteran...
thewird
What's wrong with a Billet 6765 DBB* !? You'll see T04Z (or better) spool charateristics with HUGE power potential up top... especially with a nice/big streetport...
~ Kayvon
Old Nov 17, 2009 | 01:13 PM
RacerXtreme7's Avatar
NASA geek
I agree with both of you (Zero R & Trots*88TII-AE).
Billet is more beneficial to smaller and mid framed turbo's for a couple reasons.
One the aforementioned shaft area to over all size ratio.
Another being the blade thickness to over all size too.
The last being the larger you go, the higher the tip speed/mach numbers on the outer fins per given shaft speed. It's a law of physics that cannot be gotten around. Some of it can be fixed with back sweep, but it has diminishing returns.
~Mike...........
Old Nov 18, 2009 | 08:04 PM
enzo250's Avatar
IRS Champion
I was also told around Dec..
BTW the gains on the 4508 are pretty impressive as well...
Old Nov 18, 2009 | 10:27 PM
thewird
I'm just speculating that the GT35 will be included in the GTX line down the road.
Old Nov 18, 2009 | 11:09 PM
thewird's Avatar
Ah ic, anyone have any inside info on when Garret will be looking into launching something smaller?
thewird
Old Nov 23, 2009 | 04:33 PM
Turblown's Avatar
Turn up the boost
I've got a few of the new billet Gt42s here now.. There is a huge aero change to the standard stuff...
Old Nov 23, 2009 | 07:11 PM
ScorpionT's Avatar
How did you get them so early?
Old Nov 23, 2009 | 07:31 PM
Dirty bastard! Pics or die!
Old Nov 23, 2009 | 07:45 PM
Havoc's Avatar
ok ok, how much
Old Nov 23, 2009 | 07:54 PM
Turblown's Avatar
Turn up the boost
Gtx 4202
double post..
Old Nov 23, 2009 | 07:55 PM
Turblown's Avatar
Turn up the boost
Pixs...
Old Nov 23, 2009 | 08:20 PM
ScorpionT's Avatar
Looks crazy with the 11 full height blades. But how did you get one already?
