Sponsored by: CARiD
2nd gen NA wont start.....please help
Old Nov 16, 2009 | 07:44 AM
knightballplaya's Avatar
this morning i got up to go to class and my car wouldn't start, it is cranking over nice and strong, when i crank it it does smell like gas near the front of the car so im thinking it has gas and isnt getting spark, keep in mind i drove the car just yesterday and it worked fine, thanks for any suggestions
Old Nov 16, 2009 | 07:46 AM
farberio's Avatar
NASA-MW ST4
Its probably flooded. Unplug the CAS, or the EGI fuse and crank over for 10-20 seconds then plug back in and try to start.
Old Nov 16, 2009 | 08:11 AM
thanks for the advice, i tried that and it sounded exactly the same b4 and after.....i gonna take the spark plugs out and clean them up and try that i guess
Old Nov 16, 2009 | 01:05 PM
KhanArtisT's Avatar
Former FC enthusiast
Check fuel pump voltage, they're known to have grounding problems.
Old Nov 17, 2009 | 03:25 PM
thank you for the advice ill keep u posted im working on it now
Old Nov 17, 2009 | 04:19 PM
http://www.youtube.com/watch?v=S14sbZNGAjY
that car still will not start, this is a video of it turning over, when i tested a spark plug a flame shot from the spark plugs hole which seems to me then its getting gas and spark just fine, im fearing the worst of a bad apex seal, thanks for your help and i hope i get some more of it
Old Nov 17, 2009 | 05:26 PM
Jay Efini's Avatar
in fear of a seal have you cheacked compression at all? it sounds more like its flooded though, pull the EGI fuse again crank it for 10-15 wait a min or two and do that a couple times see if any gas is coming out of the plugs
if so then its still flooded..we had this happen to a car and just put it into the shop and just left the plugs out for a couple days while we got new ones and once they went in we tossed on jumper cables and it started without trouble..
or as mentioned could be the fuel pump grounding aswell
hope this helps a little
Old Nov 18, 2009 | 04:03 PM
alright its defiantly not flooded i tried the steps u both mentioned above multiple times and still nothing, im going to try to get a friend around whos better with electronics to check if the feul pump is grounding, im not all to sure on how to check that out.....thanks for all the help
Old Nov 21, 2009 | 10:28 AM
barney1omm's Avatar
STEP ASIDE !!!!!!!
pull start
demetlaw
Oct 2, 2015 06:22 PM
