Water temperature gauge inoperative, coolant light on?
Old Nov 15, 2009 | 12:30 PM
rotarygen2's Avatar
hey guys... my dashboard lit up telling me the exaust overheat... add coolant...and my temp gauge isnt working... anybody have any ideas...thanks
Old Nov 15, 2009 | 08:30 PM
Rotospeed's Avatar
have you changed any thing on you car? carb? timing? you could be running realy rich with a bad cat.
more info on the car pls.
Old Nov 16, 2009 | 11:59 AM
Kentetsu's Avatar
Check the alternator belt. You lose that, and all of the idiot lights will light up on the dash.
Old Nov 16, 2009 | 02:11 PM
ourxseven's Avatar
1/1 scale Hot Wheels
bad or weak grounds will do it too .... my 79 add coolant light fades in and out when its cold outside .
Old Nov 16, 2009 | 07:08 PM
rotarygen2's Avatar
no cats on car strait pipe, havent done any big changes in a while ....do have a dellorto carb put that on over a year ago tho.. and the alternator belt is still on...
Old Nov 16, 2009 | 11:12 PM
DivinDriver's Avatar
1st-Class Engine Janitor
Are you low on coolant?
Probably your ground connections need cleaning.
Old Nov 16, 2009 | 11:31 PM
Siraniko's Avatar
RX for fun
loose 2 prong connector behind the alternator
Old Nov 20, 2009 | 12:41 PM
rotarygen2's Avatar
nope water level is good and that prong is conected
streetlegal?
Mar 17, 2022 02:46 PM
Snoopy FD
Dec 8, 2015 01:45 PM
gtcd
30
Aug 19, 2015 02:44 AM
