secondary injectors
Old Nov 12, 2009 | 02:26 PM
SlidewayStII's Avatar
KS secondary injectors
at what rpm do my secondarys open up? im having tearable air to fuel at 5500 and up at WOT
Old Nov 12, 2009 | 03:09 PM
gracer7-rx7's Avatar
needs more track time
What model?
Full mod list?
What do you mean by "tearable air to fuel"?
Do you have a wideband O2 setup? If so, what specifically are the air fuel ratios?
Old Nov 12, 2009 | 03:40 PM
Aaron Cake's Avatar
Engine, Not Motor
I think the username means a TII, in which case it's 3800 RPM and 2" of vacuum.
How do you know the A/F ratio is wrong?
Old Nov 13, 2009 | 07:24 PM
KS
well at 5 my a:f goes to about 16:1 so its a tune issue not a injector issue? whats a good size injector to run with maybe 15 psi of boost from a t61 t4. i have a safc, installed after this issue trying to "chase down the issue" i got it at +25% and its a little better but still no good. now its at about 15.5:1... any ideas? im getting drained. about to say **** it go 20b and get a whole new tune lol. and im curently on 8 psi t4 61 trim stock ECU
Old Nov 14, 2009 | 11:00 AM
Aaron Cake's Avatar
Engine, Not Motor
You're not going to have a very reliable setup running any upgraded turbo on a stock ECU.
What injectors are you running now? I'd suggest at least 900CC secondaries but you won't be able to tune those very well with the S-AFC.
A standalone is the way to go. If you continue this way, you will be building an engine very soon.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
ZacMan
Sep 19, 2015 09:20 PM
