Best Oil Choice
Old Nov 11, 2009 | 03:04 PM
patmac6075's Avatar
Once a Marine.....
WI Best Oil Choice
What weight oil is best for a rotary? The manual calls 10w-40, but most newer (piston) engines use a much lighter 5w-30 partly because the thinner oil causes less drag and improve mpg (I said partly!). Will the same thinking go for the rotary? My car has been pretty good with oil (2.5k since last oil change and down only about 1/2 QT.), so I'm thinking I should go with the thinner oil for the cold Wisconsin winters.
What say the experts?
Thanks
Old Nov 11, 2009 | 03:09 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The FAQ has a chart from the factory service manual. Oil weight should be chosen by temperature range in your area.
13
Jan 9, 2018 11:19 AM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
