lean like sean john
Old Nov 9, 2009 | 08:32 PM
SlidewayStII's Avatar
KS lean like sean john
under WOT about 5k im lean as a mo fo, like 16:1 any ideas? t61 t4 on 8-9 pounds
Old Nov 9, 2009 | 09:14 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Yeah, increase injector duty cycle at 5000 rpm & 8-9 psi. I'm assuming you're running a standalone EMS, and if you continue to lean out like that, the engine will be toast.
Old Nov 10, 2009 | 08:30 AM
Aaron Cake's Avatar
Engine, Not Motor
I don't think you are that lean. You'd know if you were because you would be checking your mufflers for apex seals.
How are you reading this? What are your AF ratios throughout the pull? Is this lean condition sudden, or sustained? What management?
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Einheri
Oct 7, 2015 12:23 PM
93FD510
Oct 1, 2015 02:00 PM
