gauges displayed on car monitor/dvd?
Old Nov 7, 2009 | 09:52 PM
R-R-Rx7's Avatar
Rotor or no motor
Havent seen anything being available for this.
Anyone seen such thing?
THanks
Old Nov 7, 2009 | 10:01 PM
jaggermouth's Avatar
Will TIG for 20b
Just when people have standalone systems, but haven't seen anything else.
THanks
Old Nov 7, 2009 | 10:24 PM
purerx7's Avatar
Registered User
HKS camp would be what your looking for. Here is a picture of one in a nsx, I believe this is the first version though:
Old Nov 8, 2009 | 06:59 AM
R-R-Rx7's Avatar
Rotor or no motor
thats that i am looking for... thanks guys
but it sais its used with obd2... Can you add the sensors separately instead?
Old Nov 8, 2009 | 12:06 PM
purerx7's Avatar
Registered User
yes, they also have an ob2adapter that will allow you to set it up on non obd 2 cars. You have to purchase all the sensors separately and can be quite expensive, all of the information is available on HKS usa's website.
Old Nov 10, 2009 | 06:19 AM
David Hayes's Avatar
PLX makes a device that can real time display data:
http://www.plxdevices.com/datalogger.html
You can also build your own system from vendors like http://store.mp3car.com/Car_Computer_Systems_s/25.htm
A few guys have done it in the past. I looked into this a few years ago but ended up going with the line of PLX gauges instead to display my data.
Old Dec 6, 2009 | 10:50 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
That's the current 2nd gen version of the HKS CAMP. I installed the 1st gen version CAMP in my S5 TurboVert and LOVE IT!!!! Added bonus is you can change the color of the virtual analogue guages to match the stock gauges.
Old Dec 7, 2009 | 06:23 AM
The HKS Camp 2 requires (if I read the literature correctly) either an OBD2 input or the purchase of HKS sensors. It also does not include the monitor.
http://www.hksusa.com/info/?id=3474
As we don't have OBD2, we would be limited to 6 inputs and would need to purchase the optional HKS sensor units. So, this will set you back over $1,200 without the monitor as you'd need to buy all of the sensors, and the meter interface. Then throw in the monitor, and you are up to about $1,400. Ouch! For this, you can monitor temps, pressure, and boost and as I read it, no more than 6 readings. So, you could do boost, water and oil temps, and oil and fuel pressure, and egt and that would max out the system. It does look like you con combine it with your NAV system so that is a plus.
A similarly configured (including the monitor) system from PLX would cost about $720.
Old Dec 7, 2009 | 11:28 AM
Black7Conv's Avatar
another economical unit is the R-Vit DS data station from blitz but it requires an obd2 input as the hks one..
Old Dec 7, 2009 | 10:31 PM
teenwolf1393's Avatar
BROKEN AGAIN
there was a high end flip out dvd player that had an assortment of guages that could be displayed on the flip out. its in one of my magazines ill look for it and post my findings for you.
andyvideopro
Aug 20, 2015 10:55 AM
gtcd
30
Aug 19, 2015 02:44 AM
LMBTG
Aug 15, 2015 01:43 PM
