dash light dimmer
Old Oct 30, 2009 | 10:01 PM
snivley whiplash's Avatar
brappppp brappppp
WA dash light dimmer
1985 gs, how to test the dash light dimmer? I have no dash lights, but the console and radio light up with head lights on....suggestions.
Old Oct 31, 2009 | 10:06 AM
BigBoss's Avatar
No lag!
ummm i believe theres this little **** on your right where you can adjust it...
Old Oct 31, 2009 | 12:28 PM
AZKC's Avatar
When I worked in parts we sold alot of those dimmers. You would have to test it with a meter.
Old Nov 1, 2009 | 07:04 AM
brappppp brappppp
what is the wiring color for power in from the combo switch?
Old Nov 2, 2009 | 10:55 AM
Kentetsu's Avatar
Under the shift boot, there are two wire ends that look like they should be plugged into each other. If you do plug them in, then you immediately burn up the dimmer switch. Happens to almost everyone at some point, if they ever pull the shift boot off.
For a temporary fix, you can pull the switch out and jump two of the connections. This will give you dash lights at full brightness (mine is still hooked up that way).
Old Nov 2, 2009 | 09:20 PM
brappppp brappppp
thanks for the info
The1Sun
Sep 7, 2015 10:21 PM
