Megasquirt Need help starting up new firmware. MS2 V3 2.1.0 firmware
Old Oct 19, 2009 | 11:05 PM
immanuel__7's Avatar
Ok so we upgraded to 2.1.0, so that i can use my boost controller and as many ppl keep telling to do so. ... we then started to reconfigure my settings importing my data(vex files) and replicating screen shots. we can get the car to start but it wont go under 9ms of injectors pw with both, no matter how low we make the fuel ve table it seams to stay the same. the car seams realy rich and runs like crap like timing is off but used to be fine.. im running the stock injectors street ported stock turbo. stock S5 temp sensor with the GM intake temp sensor.
can u guys have a look at my msq file and let me know whats going on??? and or if some one has an msq file i could use to start my tuning with that would be cool THANKS!!
Old Oct 20, 2009 | 03:43 AM
a_reyes1014's Avatar
Well in your engine constants you have 4 injectors instead of 2 and staged injection is off when it should be on. Start with that and see if that helps. Let us know how it works out. Also there is a 2.1.1 firmware with new staging features which is the latest firmware I believe. I think you can find it on the ms3efi.com/forums. It was lost in the msextra.com crash. It works fine for me so far.
Old Oct 20, 2009 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
What he said. Also your required fuel is huge which may seriously limit how much fuel you can take out of the VE table before you run out of VE table.
Your EGO is set to narrow band, which won't cause your issue, but won't help.
Your idle control is set to 15 minute IAC, which is odd. Won't cause the problem, but still wrong.
Staged injection is turned off.
Old Oct 20, 2009 | 09:46 AM
Cool thanks for the info, I'll give that a try hope she runs!! I need my car for the morning.
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
