cold air intake...
Old Oct 18, 2009 | 11:01 PM
O_Adam_7's Avatar
Question cold air intake...
does anyone know where i can find a real good cold air intake system online for a 86 GXL n/a?
i keep finding replacement parts. driving me insane
Old Oct 19, 2009 | 09:39 AM
Aaron Cake's Avatar
Engine, Not Motor
Your car came from the factory with a cold air intake.
There are no aftermarket cold air kits for the 2nd gen.
Old Oct 19, 2009 | 07:46 PM
w.sen's Avatar
In a Bucket
On ebay you can buy a maf adaptor the bolts on the maf are M6 X 1.0 pitch it is a 3" cone filter that fits it.. By removing the stock air box there is a hose to the air pump... I've seen sent ups to put a small breather fliter on the air pump
I bought the maf adoptor and the cone filter for 20 bucks 65 cents for the bolts.. The maf kit comes with a plastic gasket for the maf..
I will say noticeable differance in an N/A
Old Oct 20, 2009 | 04:41 AM
MadScience_7's Avatar
Too old for this
If you don't mind doing some cutting, you can get one of those MAF adapters and some 3" pipe and relocate the cone filter just above the brake cooling duct. You have to relocate the washer fluid reservoir and cut out just enough of the metal around where the washer fill tube went through to fit the 3" pipe. I also cut out the top of the brake cooling duct for more airflow, but the filter gets dirty really fast now.
Old Oct 20, 2009 | 09:14 AM
Aaron Cake's Avatar
Engine, Not Motor
Or simply use a cone filter and build the cold air box around the stock cold air intake snorkel.
FlatVermin
22
Sep 27, 2015 05:42 AM
The1Sun
Sep 7, 2015 10:21 PM
