Sponsored by: CARiD
so i replaced my transmission
Old Oct 18, 2009 | 02:56 PM
durham877's Avatar
how much transmission fluid do i use its a manual on an 85 rx7 and anything i should do before trying to drive it again that i would not think of. im 18 and have only switched out an automatic before
Old Oct 18, 2009 | 09:12 PM
farberio's Avatar
NASA-MW ST4
You should fill it till oil starts pouring out of the fill hole, or if there are two holes one will act as the fill hole and when oil starts pouring out the other its full.
It will probably take approx 2qts of oil, be careful not to over fill. Make sure your car is level.
Old Oct 19, 2009 | 09:21 PM
durham877's Avatar
sooooooooooo how awsome am i that its all done but now the car still wont move i can start it put it in gear but it wont move
Old Oct 19, 2009 | 10:30 PM
farberio's Avatar
NASA-MW ST4
Well....lets see here.
You are sure everything was put back together correctly? The clutch pedal is all hooked up?
What happens when you put the car in gear? Do you hear anything?
Old Oct 20, 2009 | 12:07 AM
john ward's Avatar
oi oi oi
Did you start with car in gear. Can you not put in gear. why did you replace transmission. What does pedal feel like.
Old Oct 20, 2009 | 01:05 AM
durham877's Avatar
k i will listen more tommarow morning the clutch fells little resistance. when the car is in gear i dont go anywhere i rev teh engin and the car moves very slightly. i didnt start the car in gear should i? i will check on the clutch connections any ideas on where to find out how to do that if the master cylenders off would that be the case. i can put it in gear with no problem at all. i replaced it for the same reason that i have now. thanks 4 the help
Old Oct 23, 2009 | 10:41 PM
farberio's Avatar
NASA-MW ST4
Your problem does not sound like a problem with the trans.
The only thing I can think of is a badly worn out clutch.
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
