New 12A Won't Start
Old Oct 13, 2009 | 09:57 PM
grchase65's Avatar
Wedge
New 12A Won't Start
Just put in a rebuilt 12A in 85' it will run as long as I put gas in carb. It sat for a long time 1yr. should I rebuild carb? bought a kit just did not want to F with it. I can see gas in the little windows on side of carb.
Old Oct 14, 2009 | 12:18 AM
mar3's Avatar
Administrator
Hmmm...if the gas has been in the tank for a year, it may not be good anymore. On top of that, gas and water will mix, so a carb that has gas in it but isn't run so the water can be "burned off" will tend to start getting things stuck internally over a year's time. Get some Gumout Carb Cleaner and hose the thing down. Get two cans and hose it down, inside and out. Blow it down the exposed air jets, replace the gas in the gas tank or add some Stabil, then try to start and run it on what ya got.
But you are starting it, eh? What part of Dallas? There is a LOT of support for rotaries in the Metroplex ~ "amateur", small business type tuners and also pro shops. Pick your poison.
Mario III
Old Oct 14, 2009 | 12:32 AM
grchase65's Avatar
Wedge
Well I did not tell you I did drain the gas and put new in and I may have fell short on sitting a year prob. more. When I fill the carb and it is running and I am pumping the gas no more is going in the carb. Pump is working fine that is how I got the old gas out just trned on the key and pumped it all out. To my knowledge carb has never been off...should have rebuilt it when I put new engine in
Oh I live in Rowlett, know anyone that will rebuild it.
Last edited by mar3; Oct 14, 2009 at 01:37 PM. Reason: Merged back-to-back posts...
Old Oct 14, 2009 | 09:05 AM
diabolical1's Avatar
it very well may be the carburetor itself. however, after reading this part you wrote, you didn't mention replacing the filter after using the pump to empty the tank. did you? also, check the filters in the hard lines of the carburetor. try those before condemning the carburetor itself.
Old Oct 14, 2009 | 10:28 AM
Kentetsu's Avatar
All the information you could ever want about the carb, and lots of writeups on troubleshooting and rebuilding. www.sterlingmetalworks.com
Good luck.
Old Oct 14, 2009 | 09:45 PM
grchase65's Avatar
Wedge
Thx! pulled the carb last night. Started tearing into it today using a haynes book (not too impressed) I am about half way done tearing it apart. I will keep my progress up here and I will check into you link.
Old Oct 15, 2009 | 08:28 AM
grchase65's Avatar
Wedge
Odd part?
Well pulled the assembly with the float out and to my suprise no needle and seat just had a one piece with a clear ball on top. Does anyone know if I should replace the one that came with the re-build kit. here is a picture:
Old Oct 15, 2009 | 10:57 AM
Kentetsu's Avatar
Go ask Sterling: www.sterlingmetalworks.com/bymc
Old Oct 15, 2009 | 03:18 PM
grchase65's Avatar
Wedge
I did thanks and he told me those I pulled out are better than the re-build ones by far and are hard to find, so clean em and use em. thx for the link!
Old Oct 20, 2009 | 01:19 PM
grchase65's Avatar
Wedge
Carb is re-built
Well i re-built the carb this weekend and all went well the car starts now and runs on it own. The idle is rough but beings it is new motor I need to set timing and prob. a few other things. If anyone has a order that I need to follow it would be greatly appreciated.
alphawolff
Nov 17, 2015 05:57 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
Im faster
Aug 19, 2015 02:57 PM
