Drifting Discuss Drifting and drifting techniques here.
Welded Diff?
Old Oct 11, 2009 | 10:53 PM
wankle1's Avatar
93' BB R1
Welded Diff?
Is welding the diff an okay alternative to LSD? i'll be going with LSD eventually.. but just needing to get rid of the 1 wheel peel.
Old Oct 11, 2009 | 11:02 PM
RotaSpinna69's Avatar
Sure
Old Oct 12, 2009 | 05:18 PM
Djonyx's Avatar
Old Oct 12, 2009 | 05:32 PM
JebusFC's Avatar
Yep, welded diff is great.
Old Oct 12, 2009 | 05:46 PM
ilia's Avatar
Chicago
I like welded fine. I've had it for almost three seasons now and am in no hurry to get an LSD.
Old Oct 12, 2009 | 06:16 PM
dkwasherexd's Avatar
Garage Life
yup!
Old Oct 12, 2009 | 06:31 PM
s13skank's Avatar
Just like everyone said, yes!
Old Oct 12, 2009 | 11:01 PM
dcwfc3s's Avatar
only that sucks is running the smaller nonturbo axles and STUB SHAFTS wich are weak. ive been known to throw serious fits when the shafts break at practice events.
i looove welded though- - except for pushing the cars around...
i do have a tomei 2-way on the table, waiting
Old Oct 12, 2009 | 11:38 PM
nightridaz777's Avatar
Welded Ass Hell
welded diffs do wonders!
Old Oct 13, 2009 | 12:12 AM
wankle1's Avatar
93' BB R1
Thanks!!
Old Oct 13, 2009 | 05:56 AM
Garage Life
from my experience..
I have broken about 3 na stubshafts, and one na halfshaft.
I have broken 2 rear subframes where the diff mount bolt up to
I am on my third Na diff.
Ive been getting paid to replace diff mounts
I can swap t2 diffs without unbolting the stock dual exhausts by myself
I can swap rear subframes
Because of all this work I am now a master of the fc3s rearend. lmao
When a stubshaft snaps, the other piece is stuck in the na diff forever, and all the shards of metal will fck up the diff's bearings. You could pull out the broken stub piece and replace it, but your diff will wine and bearings will seize soon. True story, my diff seized on the fwy.
The key to keeping your na stub shafts and halfshaft and rear subframe diff mount tab in one piece is :
-make sure you have thick gear oil
-pinnion snubber
-no standstill burn outs with 18x9.5s and 255s with 35 psi
-no hard launches with low tread wear tires
-when you spin out, dont floor it , you will snap the stubshaft or halfshaft
Once you get going, you can clutch kick in the straight away to make up for not launching your car. I havent broken a stub axle doing that so far.
All this only applys to you t2 guys tho.. I really doubt a na stock na motor could break a stubshaft haha
I wish I was rich , Id get a kaaz or tomei 2way t2 rear end already..
Old Oct 13, 2009 | 09:03 AM
dcwfc3s's Avatar
your sooo dreamy.
Old Oct 13, 2009 | 04:20 PM
Garage Life
dcwfc3s is going to be the next jtp
are you still running a Na rear end?
Old Oct 13, 2009 | 09:30 PM
dcwfc3s's Avatar
yeah, rockin the same welded for 2 years now.
2-way is chillin on the table...
ballin on a budget.
i traded some labor for the diff.
Old Oct 13, 2009 | 09:39 PM
dcwfc3s's Avatar
wow thank you. my pals gary and jeremy kill it too.
Old Oct 14, 2009 | 04:27 PM
s13skank's Avatar
your sooo dreamy.
Yes he is, Dk you remind me of my cute asian teddy bear i have. I just wanna pick you up and hold you jk
Old Oct 14, 2009 | 09:16 PM
rx7fitz's Avatar
Yeah its fast...
are the auto rears less beefy than the 5spd n/a rear ends?
also when i do a burnout from launch or a slow roll my shifter jumps around in the hole and its scary but when im sliding it doesnt do it... what is the deal?
dk your car reminds me of domo kun lol
Old Oct 15, 2009 | 03:27 PM
Garage Life
tranny mounts are bad! or maybe your tranny mount bolts are loose! check it
Old Oct 19, 2009 | 06:19 PM
dcwfc3s's Avatar
ok-----
my over 2 year old welded diff failed this weekend at pbir. on saturday, i broke an axle, on sunday the diff locked up while slowing down from going real fast. - it was makin some noise that ignored and wrote off as tires...
Old Oct 26, 2009 | 11:19 PM
NoPistons!'s Avatar
Tango Down
I run a shimmed tII clutch type.
Refuse to run a welded.
People stare, people laugh. **** that. I still have one sitting in my basement, unused. Just incase someone wants to buy it or my clutch type ***** the bed.
Old Oct 27, 2009 | 11:50 PM
dcwfc3s's Avatar
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
James Knox
Oct 5, 2015 07:56 AM
Turblown
Sep 30, 2015 05:58 PM
