Vacuum switch
Old Oct 8, 2009 | 03:23 PM
blackimpala's Avatar
Vacuum switch
Hi, I'm just hoping that someone will be kind enough to help an outsider. I have a diesel 4X4 and I found a mod to be able to use 2wheel low but it says I need a vacuum valve from a 87 RX7.
"The vac solenoid I used is off of I believe an 87 RX7.. The solenoid is part of the emissions system... RX7 nuts call it the rats nest and more often than not pull it all off.. about 6 or 7 solenoids per engine..
The solenoid is perfect for the 2LOW because after closing off from the vac source it vents to atmosphere through a small filter to remove the vacuum from the line going to the t-case... Oh ya and its cheap.."
Can someone tell me the name of this valve so I could get it at a parts store or where it is on the engine so I could get it at a wreaking yard.
Thanks
Floyd
Old Oct 9, 2009 | 10:26 AM
mar3's Avatar
Administrator
The 1stgen's have the rat's nest also, so it's curious that the "tip-of-the-day" would specify a 2ndgen set up. Still, let's see what the 2ndgen guru's have got to say since it does mention venting the transaxle, something the 1stgen's def don't have.
Mario III
alexdimen
20
Oct 23, 2015 01:50 PM
ZacMan
Sep 19, 2015 09:20 PM
Frisky Arab
Sep 4, 2015 06:17 PM
rotor_veux
Sep 3, 2015 07:10 PM
