1980 wont start issue
Old Oct 7, 2009 | 11:56 PM
nickin520's Avatar
ok so heres the problem its a 1980 carb model obviously it wont start unless you spray it with a little carb cleaner then it runs fine all the fuel system has either been cleaned or is new someone has 2 fuel filters in a row on it near the rear tire and they are very close together could that be the problem or what else could it be when its running it runs great jost wont start without a shot of cleaner even right after it is shut off also does any one have good pics of the right side of the motor under the air cleaner i need to make sure everything is ran corectly vacuum hose wise thanks nick
Microtech
30
Apr 23, 2016 06:37 PM
1993fd3sracer1
29
Oct 13, 2015 01:57 PM
1993fd3sracer1
20
Sep 7, 2015 11:50 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
