68 VW fastback rotary build.
Old Oct 5, 2009 | 08:46 PM
Shawn22's Avatar
I picked up this old 68 VW fastback i all so have a 74 super beetle that i was thinking of doing the same thing to but didnt want to chop her up. I read up on the swap and i saw it can be done. Any one on the forums every done this or know of any web site that has done? Seen a vid on youtupe with a rotary bug. http://www.youtube.com/watch?v=woqiFrnZqvE
Old Oct 8, 2009 | 07:55 AM
wmelon137's Avatar
Meat Popsicle.
I would think this kind of swap would be much more difficult than the bug swap, just due to how the engine is placed in the car. The type 3's don't have the over engine clearance that the bugs have due to not having the upright fan shroud.
Personally I'd keep the type 3 factory and put the rotary in the super beetle as they're much more common.
Old Oct 9, 2009 | 04:23 PM
Fire85GSLSE's Avatar
Chad Carson
man, when I lived/grew up in tampa I saw this swap often with the local guys at the lakeland dragstrip.
quick search took me here -
http://www.mazdatrix.com/VWkit.htm
http://bb.bbboy.net/vwengineconversi...wforum?forum=1
A friend of mine in Ga (atlanta area) is a rotory guy and races a bug. He might be able to help you. I will forward this to him.
Old Oct 9, 2009 | 05:11 PM
ray green's Avatar
Gone
A bug, yes, a wankel makes them interesting. Rotaries go good in Porches too.
But that classic baby blue VW type 3? NO!!
Old Oct 9, 2009 | 07:58 PM
rolandgreauxii's Avatar
Mr. RPM
wmelon137 - The swap is definitely doable. The type 3 fastback has alot more room in the rear than a bug. This is a good thing. Of course a rotary is much smaller than a flat 4 cylinder. You may possibly have to make a rear cover for the engine after the swap. I do not think that the original will work. With this conversion you would use a KENNEDY ENGINEERED PRODUCTS VW to rotary kit. Are you planning on doing the swap yourself or letting a shop do it? Let me know.
-roland
Old Oct 9, 2009 | 10:52 PM
Chad Carson
-roland
Thanks for replying Roland. I figured you could help on this VW subject fo sho!
Old Oct 9, 2009 | 10:55 PM
Mr. RPM
No problem Chad anytime!
Old Oct 11, 2009 | 08:33 AM
wmelon137's Avatar
Meat Popsicle.
-roland
I've actually been working on the swap for a while now. I only mentioned the space as a 13b with intake manifolds attached is almost exactly the same height as the original 1600 I took out of my KG.
Here's some older pictures, I'm almost to the point where I can start wiring everything up.
Old Jul 16, 2012 | 10:25 AM
BuBBaStuBs's Avatar
Young Lad Customs
You ever get this thing running wmelon137?
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
