Introduce yourself New members post about yourself here...
FC market value
Old Sep 28, 2009 | 11:32 PM
nedsdead's Avatar
CA FC market value
Hi there. First time posting. I've owned 3 second gen RX7's - a base 1987 coupe, a low mile Turbo 2 and an '89 GXL coupe. I'm thinking of buying a black 1991 coupe that's got 108k miles. It has the tilt wheel and cruise. Everything is original other than the stereo and the clutch and flywheel. The motor runs strong, and there don't appear to be any leaks. Belts and hoses need changing, needs an antenna, 2 new tires, a detail, fluids changed and a tuneup (probably more). It sat outside for the past year and so the paint is oxidized and the dash is badly cracked and has bubbles. Every hinge in the interior seems broken, the passenger door only opens from the inside. The body is very straight and the 2nd owner who has it now seems to have taken care of it mechanically. What do you think it's worth? Thanks for your advice.
turbodreamz22
28
Nov 10, 2023 11:08 AM
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
jsesq
27
Sep 25, 2015 11:10 AM
