Megasquirt ready to order my MS
Old Sep 24, 2009 | 11:59 PM
wankelbug's Avatar
ok a few questions this if for a 85 gsl-se engine with the stock FI do the stock air temp sensors work with MS? what about the coolant temp sensors? TPS? cant find out but does the engine have an idle air controll valve? should i use the relay board?
Old Sep 25, 2009 | 09:03 AM
Aaron Cake's Avatar
Engine, Not Motor
You can use the stock IAT and CLT with a simple resistor swap and firmware reflash on MS1, or just a sensor recalibration on MS2. However I always recommend that people go with the standard GM sensors due to their minimal cost, ubiquity and newness compared to 24 year old stock stuff.
TPS?
You can use the stock TPS, or mount up a full range TPS (such as a Ford or GM unit). The advantage of the full range TPS is that you have more tunability if using TPSdot for accel enrichment.
Yes, but you can't use the Megasquirt to control it. If you intend to use an idle valve, you will need to retrofit a 2nd gen BAC or another two wire PWM valve (found on many, many, many vehicles).
I've never found it necessary.
Old Sep 25, 2009 | 10:58 PM
wankelbug's Avatar
awesome. im going to have many more questions. this is being shoe horned into a 1970 vw bug so its a little unique. should have specified im planning on ordering the newest version available. 3.??
Old Sep 27, 2009 | 09:47 AM
Aaron Cake's Avatar
Engine, Not Motor
If you are ordering a V3.57, you want an MSII processor and the Zeal daughtercard. The daughtercard contains the VR circuit you will need as well as several extra outputs. With the 3.57 you don't have a prototype area to install this stuff as you normally would on the V3.0.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
