Still not running right ?
Old Sep 24, 2009 | 04:41 PM
A7RXY's Avatar
I have had the carb rebuilt and fitted, but the engine still will not rev above 6500 rpm.
So far I have changed the fuel filter cleaned all the lines out and had the carb rebuild, and after checking that all plugs are sparking, I have been avised to disconnect the exhaust to see if that is blocked, I will try this tomorrow.
I should mention that the car has been left standing for 11 years, but started every so often, when I stopped using the car it was running ok.
Any other ideas ?
Old Sep 25, 2009 | 10:53 AM
Kentetsu's Avatar
Have you checked the timing? Is the fuel pump delivering enough fuel?
Lots of carb info can be found at www.sterlingmetalworks.com Sterling might be able to help you get her running right. Good luck...
Old Sep 25, 2009 | 12:52 PM
A7RXY's Avatar
Thanks for your reply, thats a great website, I wish we had someone like that in the UK.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
