Haltech E6X LS1 Coil RPM Signal Question
Old Sep 23, 2009 | 07:34 PM
MFP10thAnn's Avatar
I have a 10th Ann that I have recently converted to an E6X with MSD Multispark LS1 coil primaries, and OEM LS1 coils for secondary ignition...
My issue is that my stock tach only read approx 1/2 the rpm readings of the haltech. I am using the T1 coil signal from the Haltech, which is spliced into RPM wire from the OEM secondary coil harness.
You guys running LS1 coils, are you using the stock tach? If so, how are you getting an 'accurate' signal? Are you taking the signal off the primary coils?
All of my wiring and Haltech settings are correct.
Any insights would be appreciated.
Old Sep 24, 2009 | 09:17 AM
classicauto's Avatar
Crash Auto?Fix Auto.
Use the tach output wire on the haltech, and connect it to the loose spade (bullet? its been a while) terminal near the trailing coil wiring. That feeds the tach a clean signal from ECU.
This is how I run it on my current ECU which uses seperate coils wired similar to an Ls1 type setup.
Old Sep 24, 2009 | 09:56 AM
MFP10thAnn's Avatar
Thanks for the response. I will give that a try over the weekend.
Spencer
Old Sep 26, 2009 | 06:13 PM
MFP10thAnn's Avatar
worked like a champ!
Old Sep 26, 2009 | 06:22 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
The Aux. Out wire, set to tacho, with a 12V pull up is how its configured. This setting also applies to E8/E11/Sport 1000/2000.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
