Drops of oil( pain in the butt pls) help !
Old Jun 7, 2002 | 07:02 PM
kelrx7r1's Avatar
TNC
Talking Drops of oil( pain in the butt pls) help !
hi guys for a while now i have been dropping oil from my fd its a
problem now as my drv way looks like **** and im pissed off at that
cause i use to have a major problem with my old t2.anyways it
of course drops oil after i drv it when i park and move car i can see
3 drops in a row going side ways.
what can it be i think its the oil meter level cause my oil gauge
drv me crazy somethimes it drops down below and shuts off for a while
and a fellow rotorhead told me that was the case but can that also
be the case of oil on the floor?
any suggestions pls.
Old Jun 7, 2002 | 07:43 PM
Pumped's Avatar
I Have that problem too, couple drops here and there, I think it may be a leaky oil pan gasket, But I heard its a bitch to install, b/c you have to remove a load of bolts, plus its a good 4-5 hrs for a shop to do..
Old Jun 9, 2002 | 03:48 PM
kelrx7r1's Avatar
TNC
I HOPE ITS THE OIL PAN THAT WAS MY PROBLEM ON MY 1ST T2
IT WAS FUN.BUT I WANT TO MAKE SURE. ANYONE ELSE ?
Old Jun 9, 2002 | 03:59 PM
could be coming from the turbos or the oil supply line.
Old Jun 9, 2002 | 11:47 PM
kelrx7r1's Avatar
TNC
HEY BRAD MAYBE I JUST STARTED NOTICING SMOKE FROM THE TURBO A LITTLE BUT ****
Old Jun 10, 2002 | 01:20 AM
kundo's Avatar
Yeah I have the same problem too. Little drops here and there. I have to rebuild my turbos soon, even though i've been telling myself that for a year now, because they are smoking. I didn't drive the car for 3 weeks and I drove I took it for a drive this weekend I can smell it, or sometimes I am at a stop and I see smoke coming out from underneath the front of the car. I figured it was the turbos becuase when I check the oil it is fine, have any of you had that problem with the smoke coming out the front end?
Old Jun 10, 2002 | 01:37 AM
wilgtr's Avatar
drop of oil
Hi:
I have this problem with my FD3. I check it might be leaking in the oil pipe from the turbo to the oil pan. The oil pipe line gasket has been change and the oil pan gasket change too but still leaking. I don't know.
Can anyone help us.
Old Jun 10, 2002 | 03:00 AM
twinturborx7pete's Avatar
Juris Doctor
i have drops too... mine come from the drivers side... very little but after a good drive i get maybe 1 or 2 drops... i think maybe its my oil pressure sensor... since it acts up... or the filter?
Old Jun 10, 2002 | 02:26 PM
kelrx7r1's Avatar
TNC
SAME THING BRO WITH ME SOMETIMES ITS EMBARASSING
LIKE WHEN IM PULLED OVER WAITING FOR MY GIRL IN A STORE OR AT A LONG LIGHT I NOTICE AND SMELL THE SMOKE
SOMEONE PLS HELP US
Old Jun 10, 2002 | 02:29 PM
kelrx7r1's Avatar
TNC
THATS WHAT I TAUGHT OIL PRESSURE SENSOR SINCE MINE HAS A MIND OF ITS OWN.BUT MINE DROPS OIL FROM THE TURBO SIDE WELL THE PASSANGER SIDE AT LEAST ITS LIKE 2-3 DOTS PERFECT SHAPED.LOL
DAMMIT ITS EMBARRASING
PLS HELP GUYS
Old Jun 10, 2002 | 02:43 PM
legendr35's Avatar
i have oil leaking out of my 2nd turbo, maybe you should check ur turbos for leaks
Old Jun 10, 2002 | 03:00 PM
Mahjik's Avatar
Mr. Links
Lightbulb
I had about three oil leaks fixed last fall. You can probably rule out the turbo oil lines. If it's leaking from there, it will usually be more than just a drop or two. When mine leaked, it was a mild river under the car.
After that, I had the gaskets replaced on the intake manifold and the oil pan resealed. Since then, I've been drop free.
sYnth.
Aug 19, 2015 06:27 PM
