feed rear arches
Yes, however you are going to need to run probably 2.5* of negative camber and nothing to wide for tire sizing for it to sit flush. I plan on running a 19 x 11 + 22 on a 295 with my feed rear 1/4's.
I plan on running a toyo r888 265 (so equates to a 275) on the rear
but i'm toying with the idea of a +29 instead...what do you think?....it just means 13mm less lip!!!!!!...and not much negative camber....if any!!!
