GT3574 Dyno results: stock port 10AE
Old Sep 14, 2009 | 10:32 AM
cbrock's Avatar
Hey guys. I just got my car back from A-spec where I had them give everything a once over and tune my GT3574 setup. The car is setup as following:
88 10 AE original 50,000 miles 115/115 compression
Stock ports
GT3574 regular runners
microtech LT12
J spec intake manifold
Greddy spec V front mount 2.75" piping
550/1650 injectors
parallel fuel setup with surge tank
walbro feeding surge tank, 044 pulling feeding high pressure
3" down pipe to dual 2.5"
At 15 PSI the car laid down 423 RWHP and 349 ft-lbs torque
File Type: pdf
Old Sep 14, 2009 | 12:32 PM
estevan62274's Avatar
#garageguybuild
Veteran: Air Force
^ nice numbers for 15 psi
Old Sep 14, 2009 | 12:49 PM
Nick_d_TII's Avatar
^ I agree. Have fun with it!~
I want some HP like that... :-(
Will the Irons hold up to that?
Right on! Rotary Power!
Old Sep 14, 2009 | 02:04 PM
arghx's Avatar
rotorhead
my 88 engine was tough. the irons took a lot of detonation. the only reason i got rid of them was because I had a chipped coolant passage
the stock ports are definitely giving you a flatter torque and powerband
Old Sep 14, 2009 | 02:49 PM
Insomniac21772's Avatar
WOW 423hp at 15 PSI on stock ports? very nice numbers!!
Old Sep 14, 2009 | 03:01 PM
cbrock's Avatar
Well if you notice the run is cut at 7k. Without additional mods to the engine it was recommended I not take the RPM higher or push much more HP out of it.
It also made this much power with a bad intake leak at the base of the lower manifold. The A-spec guys think it might have rolled 430-435 had it not been leaking during the run.
Old Sep 14, 2009 | 07:53 PM
Monkman33's Avatar
Goodfalla Engine Complete
Is this the journal bearing version?
Old Sep 14, 2009 | 07:55 PM
cbrock's Avatar
yeah the non ball bearing type
Old Sep 14, 2009 | 08:30 PM
darkphantom's Avatar
The king of the highway!
nice. i know that turbo II is going to be a sleeper
junito1's Avatar
F**K THE SYSTEM!!
Original engine? Stock apex seals? ANd other seals?
Old Sep 15, 2009 | 12:37 AM
RacerXtreme7's Avatar
NASA geek
Nice!!
Old Sep 15, 2009 | 12:50 AM
Havoc's Avatar
Decent, good to see more ppl sticking with stock porting for good hp levels.
Old Sep 15, 2009 | 03:34 AM
grimple1's Avatar
Turd Ferguson
nice. One day I'll get my stock port motor w/ 3574 on a dyno.... soon as i get it back together.
Old Sep 15, 2009 | 07:43 AM
moremazda's Avatar
Gone Race'n
Those are some good numbers for 50,000 mile three piece apex seals.
Old Sep 15, 2009 | 10:31 AM
junito1's Avatar
F**K THE SYSTEM!!
Yeah im wondering if it is the 3 peice seals.. Cause if it is 100% original motor than im going to try to push my j spec to 15 psi ont he BNR for sure!!
*nEEDS to get his haltech already*
Old Sep 15, 2009 | 11:51 AM
cbrock's Avatar
all stock internals. But the car has had a VERY easy life. All stock except for a cone filter and the boost set to 7 psi on the stock turbo the car went 14.2 @100
Old Sep 15, 2009 | 12:01 PM
cbrock's Avatar
Here's the car
Old Sep 15, 2009 | 01:37 PM
junito1's Avatar
F**K THE SYSTEM!!
IS it a Daily? How often do you WOT on full psi?
Old Sep 15, 2009 | 01:43 PM
cbrock's Avatar
The car is not my daily driver and I just got it back so I've had it WOT 3 times. A Spec didn't go too aggressive on timing or leaning it out. It seems this motor just wanted to make some power.
Old Sep 16, 2009 | 01:54 AM
Havoc's Avatar
Why the hell are so many kids afraid to push the stock engine ??
This isn't like the first person to get decent HP out of a stock block, stock ports etc
Pushed 340rwhp out of my old stock block for a good 6 yrs before I decided on a change.
Well done again to the original poster, enjoy the power
Old Sep 16, 2009 | 02:52 AM
grimple1's Avatar
Turd Ferguson
because of the misconception that the rotary is "fragile" . it's fragile when it's tuned incorrectly... or more often the case - not tuned at all.
(by tuned I mean both ecu and supporting mods)
Old Sep 16, 2009 | 06:40 AM
ProjectD's Avatar
I'm on a Boat!
^very true
Also, S4 blocks are notorious for cracking the rear iron when pushed to this kind ofpower level.
Old Sep 16, 2009 | 07:58 AM
cbrock's Avatar
A spec mentioned the rear iron when I asked how the stock internals can take the power. Basically with 425 to the wheels I'm getting border line but it should be fine. Push it to 450ish and there would be more concern.
As for the seals, provided there is no detonation there should be no problem. The combustion pressure with boost would be far less than one good detonation. With the 044 and surge tank setup there is no fuel delivery issues. With the 550/1650 injectors I was using ~75% according to Ryan at A spec.
Old Sep 16, 2009 | 10:36 AM
junito1's Avatar
F**K THE SYSTEM!!
Ok. I used to doubt pushing my motor without atleast changing the apex seals.
But you guys have shown me the light. ALl i need now is some 1680's and a haltech.=)
Old Sep 16, 2009 | 05:10 PM
moehler's Avatar
Great numbers! The 3574 really is a nicely matched turbo for 13B's.
cristoDathird
28
May 30, 2019 08:47 PM
C. Ludwig
Jan 30, 2019 06:31 AM
Clacor
Aug 14, 2015 09:17 AM
