Speed Governor
Old Jun 6, 2002 | 10:54 PM
Liquid Anarchy's Avatar
We come with the Hardcore
Speed Governor
I had origionally intended to have MD Racing re-program my ECU. It boasted quite a bit of gains, and seemed like a good Idea.
When I found out noone really does that anymore, I looked into the S-AFC, and I think that's the route I'm headed ( After all, most of the functions of the computer are just modding the fuel map )... HOWEVER...
What do you do about the speed governer? Is it still there? Any way to get rid of it? Thanks.
Old Jun 6, 2002 | 11:01 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I don't think they have one
or you mean rev limit?
Old Jun 6, 2002 | 11:32 PM
jreynish's Avatar
New Project on the Way...
fc's don't have speed gouvenors! Do they? if so please correct me!
Old Jun 6, 2002 | 11:38 PM
Bambam7's Avatar
I came, I saw, I boosted.
Yep, It's set at 100mph. Anyone who can go past that has an electrical problem, probably a ground or cold solder joint.
What's that? Everyone can go past that? Big surpise...
j/k.
Old Jun 6, 2002 | 11:44 PM
blackdragonsocal's Avatar
bwahahahaah.....Bambam had me going for the first sentence. I was thinking "Hey, I got my TII up to 120 on the way home from work today....what's up?" Then I finished reading his post and came to the conclusion that I should probably stop drinking the alcohol now. Yeah, no speed governor.
Old Jun 6, 2002 | 11:48 PM
13bpower's Avatar
s4 for life
I agree that there is now governer on the coupes, but I have heard that the verts have one at 124mph. I have only had my vert up to 120mph so I don't know for sure. Dose anyone else?
Old Jun 7, 2002 | 12:16 AM
Icemark's Avatar
You guys are wrong, in Japan they are all limited to 112MPH, but there is no speed governor on any North American models.
But if you got a Japanese ECU without a new chip installed then you could have a governor (like if you did a Jspec conversion and got the ECU).
Old Jun 7, 2002 | 12:22 AM
Zaxfire's Avatar
I have an 86 N/A and it will do 120 in Fourth gear..I just installed Nitrous today..I haven't gotten my bottle filled yet but I bet it will go faster than 120..I hope so anyway..The Zex kit might take it faster...???
Old Jun 7, 2002 | 12:33 AM
nitroracer's Avatar
Dub'N
today i went 125 in 4th and the needle was pend at 8
Old Jun 7, 2002 | 12:34 AM
"I topped out at 140, I need NAWZZZZ, 2 of em', the big ones!"
Old Jun 7, 2002 | 12:36 AM
nitroracer's Avatar
Dub'N
so did i...do u guys think there is something wrong... with my mods and im only doin 140
Old Jun 7, 2002 | 12:44 AM
13bpower's Avatar
s4 for life
Better be carful with the Nawws. I will make bolts start flying off your car.
Old Jun 7, 2002 | 12:54 AM
Poppinrex7's Avatar
i got Nas but im listenin to dre right now....
Old Jun 7, 2002 | 01:30 AM
DoriZaru's Avatar
Yeah, or you might blow the welds on the manifold. Or your spiffy diamond-tread aluminum floorboard might fall off (????- he should probably have had a word with the shop that installed those). But its all good- you can start yelling at your laptop like it's R2-freakin-D2 and then shut it. That'll fix everything.
Old Jun 7, 2002 | 02:44 AM
RexRyder's Avatar
be sure to double clutch, not granny shift, might blow an apex.
Old Jun 7, 2002 | 02:56 AM
Juan's Avatar
Im a tall midget.
My car has a speed governor. Its called a lightened flywheel.
Old Jun 7, 2002 | 03:34 AM
I guess I don't understand the above comment by Wan
Old Jun 7, 2002 | 06:31 AM
WestJaxVert's Avatar
Can you explain this, please?
Old Jun 7, 2002 | 06:36 AM
CrackHeadMel's Avatar
Learned alot | Alot to go
Old Jun 7, 2002 | 06:56 AM
FPrep2ndGenRX7's Avatar
My car has a naturally occuring speed governor. Its called low compression.
Old Jun 7, 2002 | 02:13 PM
RexRyder's Avatar
My car also has a naturally occuring speed governor. It's called "friction"
Old Jun 8, 2002 | 05:07 PM
Juan's Avatar
Im a tall midget.
Lightened flywheels lower your top speed. With a stock flywheel, I would take it to 135mph in 4th and it would still be pulling. After the lightened flywheel I max out at 125mph in 4th. Thats why I said my flywheel was my speed governor. :P:
Old Jun 9, 2002 | 06:12 AM
NZConvertible's Avatar
I'm a boost creep...
Nope. They only alter the rotational inertia of the engine, which has no effect on how it makes power.
When you say "max out", you mean redline? If you can't even reach redline in 4th, I think you broke something...
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
WyomingTII
Sep 28, 2015 10:32 AM
