Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Afr readings on rx7plviewer vs ztplviewer
Old Sep 9, 2009 | 05:34 PM
HAILERS's Avatar
HAILERS
I've been using ZTPLVIEWER almost exclusivly, but I do have a liner output to the ECU from the Zeitronix unit.
So when I download a log to RXPLVIEWER from the Palm, why does the afr read like 2.5 instead of 14.8 afr? Unlike the ZTVIEWER where all the 02 readings are in the 14.8 format?
I can look at logs ON the PALM and they read 14.8 afr as an example, instead of what I see on the PLVIEWER on the computer (see2.5 on the computer).
I read the PLVusers Guide 2.04 and don't have the drop down screens shown in that guide from Preferences.
Seems I vaguley remember having put numbers in the Analog Input Two in the past. Can't remember.
It's a V2.1.3 Bulid 2
Old Sep 10, 2009 | 10:48 AM
turbo2ltr's Avatar
You have to make sure the RX7 Viewer has the analog scaling set up like on the Palm.
In RXViewer:
Preferences -> Custom sensors -> Analog 1 (ATP) or Analog 2 (Var Res)
R.O.D
34
Jan 6, 2016 12:09 AM
Microtech
Nov 21, 2015 10:20 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
