Dyno'd 810rwhp 630 torque
Old Sep 3, 2009 | 01:44 AM
IronMdnX's Avatar
Glutton for Punishment
I pleased I hit the 800 mark.
SAE corrected
810hp at 7700
630tq at 5700
Chart will be posted as soon I can.
Boost is 25psi falling off to 23psi.
On E85
12* with 0 split at 25psi
13* with 0 split at 23psi
Power climed all the way till I let off.
Old Sep 3, 2009 | 03:52 AM
to_slow's Avatar
WoW... Nice #'s Cannot wait form my stuff to hit the dyno....
Old Sep 3, 2009 | 07:07 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
congrats.
that's a tune similar to 540 hp 420 tq on a 2 rotor which is right where you want to be before things get dicey structually w the motor.
howard
Old Sep 3, 2009 | 08:34 AM
calculon's Avatar
On flats
Congratulations!
If I remember correctly, you had your rotating assembly balanced by CLR with your new shaft. Why didn't you you let it go a bit higher in the RPM band? Not being critical AT ALL, just curious as to your reasoning.
T56 still holding up and performing nicely at those RPMs?
Nice work again.
Old Sep 3, 2009 | 12:08 PM
chohakai's Avatar
Originally Posted by calculon
Congratulations!
Nice work again.
I had my 20B rotating assembly balanced by CLR as well, and Carlos told me that with dry-sump, I can rev it to 10K RPM all day. Without it, in the higher gears, I'll need to back off when the oil pressure drops off below 100psi, since the OEM oil pump is designed for a 2 rotor, it can't flow enough volume up top. Perhaps this is the case.
Impressive numbers nonetheless! I'm really curious to find out what was the 1 degree timing change that costed you 100 hp???!!!
Old Sep 3, 2009 | 12:15 PM
IronMdnX's Avatar
Yes, it is balanced. It does make a difference. You can feel it reving smoother and quicker. I will be bumping up the rev limiter to 9k again. I set it lower because I thought there was no point of spinning it higher if the boost is already faling off above 7k. Guess I was wrong.
Besides it was getting late and I was tired, plus I had a 70 mile drive home.
T56 is holding up great. I have shifted it above 8500 a few times. No issues,still smoth.
Old Sep 3, 2009 | 12:33 PM
Japan2LA's Avatar
Nice
Old Sep 3, 2009 | 01:10 PM
IronMdnX's Avatar
Old Sep 3, 2009 | 01:16 PM
IronMdnX's Avatar
http://www.youtube.com/watch?v=g0nXPoiJiNs
Old Sep 3, 2009 | 03:17 PM
Viper GTSR's Avatar
Performance Veteran...
Originally Posted by IronMdnX
Bro, that's an absolutely retarded amount of horsepower for ONLY 25lbs of boost, wow...
Any plans to turn it up to at least 28-to-30psi?
Old Sep 3, 2009 | 03:29 PM
IronMdnX's Avatar
I am out of turbo, it is maxed out. It hits 25 and falls to 23psi above 7k.
Old Sep 3, 2009 | 10:11 PM
chohakai's Avatar
Jesus, it looks like you left a lot of hp on the table by reving to only 7700... As long as you have good oil pressure, you can rev to 10K all day. The torque curve is not bad for such a big turbo, it looks like you have 300 lbs of torque at 4150 rpm (70mph), if you lifted off at exactly 7700 rpm (130mph)
You can also turn down the boost slightly to 23psi across the board, achieving same peak hp (bragging rights) with less stress on the motor. I'd venture to guess that you'll top out at 840whp at 8400 rpm, Trading some rev for boost would be a good thing!!
Old Sep 3, 2009 | 10:29 PM
chohakai's Avatar
Originally Posted by gmonsen
Love your numbers. If he can put down anything like that reliably, its more horsepower than anybody needs or wants. With enough rubber, there's nothing around that should beat this thing in any race I can think of. Not in a road race, maybe, but everything else. Almost 4 times the horsepower of the stock car. Jesus. I prefer fewer ponies, but it would be fun to get in this thing and go hunting Porsche turbos and Ferrari F430's.
Gordon
My thinking is along the same lines, Gordon.
With my 20B 911, I'm shooting for 550whp with 10psi with a 75mm turbo (smaller), but at 8500rpm, with a extended port and phased rotors, I'm trying to trade some revs for boost. I'm all about the response and drivability, trying to mimic the power curve and the sound of an exotic high reviving NA V12 with my motor setup.
Once I've enjoyed the car for a while, then I'll add water injection later and turn up the boost to 15psi.
Old Sep 4, 2009 | 12:06 AM
IronMdnX's Avatar
I just didn't want to get too greedy. I'll put it on again in a couple of weeks and run it to 8500. I would like to smoth out the couple blips in the torque curve.
then run at 20psi(spring pressure), 23psi, then 25psi again. Just to see how much it changes.
Old Sep 4, 2009 | 08:12 AM
JBurer's Avatar
Congratulations! The car sounds great. Love the video.
You sure the pressure drop off isn't just due to your boost control system?
I see people talk about "running out of turbo" when they see boost pressure drop and don't think this is what's happening. The turbo would over-rev and go outside of it's efficiency range before it would drop boost - wastegate responding to lower-than-target boost pressure would close to try to achieve the target. I think you'd see turbo damage from over revving before you'd see boost taper off if the wastegate is closed.
Anyone else think differently?
Old Sep 4, 2009 | 10:01 AM
Viper GTSR's Avatar
My first instinct is to think that too, however your power graph is shooting straight up all the way to redline with max power right at rev-max. That's not consistent with a turbo that doesn't ave anymore in it* The drop to 23psi toward the end could very well be a wastegate or exhaust issue. Worth looking into, only becuase it appears you have another 70-100rwhp left on the table when everythings said and done.
PS; the ITS80mm's are usually good for very close to ~1000rwhp on 2JZ (Supra's) so i know they CAN flow...
Old Sep 5, 2009 | 12:01 AM
ErnieT's Avatar
Living life 9 seconds at a time
Congrats! Do you have a dyno showing rpm?
Old Sep 5, 2009 | 12:24 AM
Rxmfn7's Avatar
Do a barrel roll!
Car sounds amazing.. congrats
Old Sep 5, 2009 | 12:45 AM
Jesus loves rotaries's Avatar
Gordon
You don't even need half of this to beat F430's/911s... Around 350-400whp is more than enough in a car that weighs 500lbs+ less than most of those high end cars anyway.
Old Sep 5, 2009 | 12:52 AM
Grappler's Avatar
Turbo on the brain...
Gahhh!!! I can't believe I went to work instead of seeing this... congrats.
On the other hand if my throwout bearing hadn't gone bad I never would have heard about it...
Old Sep 5, 2009 | 01:03 AM
KNONFS's Avatar
B O R I C U A
Congrat!!!
Love the video, specially at 4:41
Old Sep 5, 2009 | 09:27 AM
IronMdnX's Avatar
I asked this question more then a year ago. I messed with the spring and same result. Even setting the the controller to 29psi if falls fast to 25 then 23.
15psi spring pressure = 25psi falls to 21-22psi
20psi spring pressure = 25psi falls to 23psi
20psi spring + shims = 27psi falls to 23psi
Any other sugestions to check, I am open to them.
Old Sep 5, 2009 | 09:38 AM
IronMdnX's Avatar
When we tried to display the x axis as rpm it would only graph up to 6000rpm. We messed with it for a while.
Old Sep 5, 2009 | 09:55 AM
IronMdnX's Avatar
Turbo map
Old Sep 5, 2009 | 12:11 PM
Turblown's Avatar
Turn up the boost
What are the complete specs on your turbo( turbine wheel size and turbine housing a/r), also what size exhaust system are you running?
