4 piston caliper?
Old Jun 6, 2002 | 12:27 AM
Skippydog's Avatar
4 piston caliper?
I am in desperate need of new 4-piston calipers. The only problem is I dont have a local import shop around here. Does anyone know where i can go for new calipers that arnt going to kill me with their prices. Im in need VERY SOON. I just went to replace my pads which are worn right down to the metal. Damn that sucks i had to put them back to gether with the shitty old pads. Two of the pistons are stuck on both calipers. I also need a set of new springs if anyone knows where to get them. Please help!!!
Old Jun 6, 2002 | 04:00 AM
DJ!
why dont u rebuild them??? i did its a piece of cake the hard part was try the sieze piston out the caliper! and will be cheaper too.
Old Jun 6, 2002 | 06:53 AM
Cameljoe's Avatar
Try your local auto parts store. I got mine at autozone. the left cost me $56 and the right cost me $85. Or you can rebuild them yourself as DJ said will be cheaper. You can get the rebuild kit from your local auto parts store too.
Old Jun 6, 2002 | 08:37 AM
Silkworm's Avatar
Has been.. hangin' around
yep, mine were 70 rebuilt from the local autoparts store.
PaulC
Old Jun 6, 2002 | 08:38 AM
rico05's Avatar
WTB S5 N/A FC
$70 for both?!?!?!?!?! I am headin to Napa during lunch, so I might as well check.
Old Jun 6, 2002 | 08:43 AM
UniqueTII's Avatar
Slow and old
I got mine from Napa for $105 each and one of them leaks...you might want to see if you can get them somewhere else.
Old Jun 6, 2002 | 09:03 AM
Skippydog's Avatar
Thanks all i will check at lunch today
Old Aug 30, 2004 | 12:00 PM
SgtRauksauff's Avatar
you know, that's kind of wierd.. I found the same thing when i was calling around for prices lately.. Is there some reason why the passenger side costs 30 bucks more?
I'm looking for a set of the 4-pistons myself, for a little project I've got going, and that really sort of perplexed me.
oh, and I found some at importpartsbin.com for $65.58 + $40.00 core, for each side. still, that's 210 bucks for a set of aluminum 4-piston calipers, not a bad deal when you consider the pricing for a set of Willwood, Brembo, or AP calipers....
--sarge
Old Aug 30, 2004 | 12:26 PM
igottafc's Avatar
RX7less **(
try ebay, sometimes you see them floating around once in a while
GKW
Sep 28, 2015 04:34 PM
