few questions ! and a problem
Old Aug 25, 2009 | 05:22 PM
harnum2009's Avatar
ok when i first got my car the turbo timer would wind down from 1 min when i turned off the key , but now it just shuts rite off when i turns off the key y is this ?
also i was fooling around with my boost controlar and noticed that my boost was at .85 kg/cm2 wondering how many pounds of boost this is aand what number is 15 psi ???
Old Aug 26, 2009 | 10:02 AM
Aaron Cake's Avatar
Engine, Not Motor
Did you turn the turbo timer off?
http://wiki.answers.com/Q/How_do_you..._Kg_cm2_to_psi
Old Aug 26, 2009 | 08:45 PM
twinsinside's Avatar
You could always try using a search engine.
I typed in kg/cm2 to psi and got an answer in like 10 seconds.
http://www.onlineconversion.com/pressure.htm
If you're not sure how to turn on/off a turbo timer I'd be careful trying to run 15 psi. something might go boom.
Old Aug 27, 2009 | 02:21 PM
harnum2009's Avatar
lol no i know how ... not that hard but i found my problem was that the wires were loose on the back off it ...
Old Aug 27, 2009 | 02:28 PM
harnum2009's Avatar
o ya how many WHP do u think 15 psi will give u with a 3 inch/78 mill turbo?
Old Aug 27, 2009 | 03:05 PM
spr258's Avatar
you need a lot more specs than what size turbo.
Old Aug 27, 2009 | 03:40 PM
Aaron Cake's Avatar
Engine, Not Motor
Yes, a lot more specs and what other mods the car is running. Such as what standalone, injector sizes, the actual specs on the turbo, etc.
Old Aug 27, 2009 | 05:31 PM
spr258's Avatar
And still after all the specs it is not a guarantee that the numbers we give you are at all close. It all depends on the tune as well as all the parts you put on your car.
alphawolff
Nov 17, 2015 05:57 PM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
