turboII engine not getting gas?
Old Aug 20, 2009 | 08:02 PM
mattfromthepier's Avatar
mattfromthepier
FL turboII engine not getting gas?
I just finished up putting a 88 t2 engine into an 88 gtu and it has compression and spark but doesnt seem to be getting any fuel. I have a defi fuel pressure gauge installed after the fuel filter and it says it has adequate fuel pressure (70-80psi), but when i try to start the engine it just turns over and over and over and never even tries to start. Also, if i turn it over for a while it doesnt seem to smell like gas in the garage? and i can only smell the marvel mystery oil i poured in the engine if i put my nose right up to the tail pipe after i try to start it. Anyone have any ideas what it could be or had a similiar problem? any kind of help or ideas is greatly appreciated! thanks!
Old Aug 20, 2009 | 11:28 PM
RotaryRocket88's Avatar
Top Down, Boost Up
70-80psi is way too high if you're tee'd into the fuel feed line. You should only see that much if you "deadhead" the line. Normal fuel pressure when the engine is not running is about 40psi. If this is a J-spec engine, you probably have the fuel lines backwards.
Old Aug 21, 2009 | 03:21 AM
Kerberos_8's Avatar
your injectors are not fireing. I had the same problem. My car was not starting because it wasnt getting fuel. Mine issue turned out to be a broken wire on my crank angle sensor.
Old Aug 22, 2009 | 09:57 PM
mattfromthepier
FL
Thanks so much rotaryrocket88!! I switched the fuel lines and it started up first try! I feel like an idiot cause i actually knew where the fuel lines were supposed to go on the jspec engine i just screwed up. thanks alot for all suggestions and help you guys! Finally got my year and a half long project on the road! woohoo!!
Rotospectre
Mar 28, 2018 03:33 PM
82streetracer
Aug 23, 2015 09:28 AM
smikels
Aug 18, 2015 01:26 PM
