ECU question
Old Aug 14, 2009 | 03:32 PM
Kaosking's Avatar
VA ECU question
OK, I posted an earlier thread about getting an error diagnostic reading about my oil metering pump. The pump was removed and was not working correctly. I purchased another usesd pump that was working and installed it. Prior to this my 93 RX-7 was running in limp mode and I figured it was because the oil metering pump was not working correctly. My mechanic had taken the ECU out at one point and opened it up to have a look and did notice some black spots on the board. I'm not sure if the ECU itself is faulty and needs to be replaced. Back to where I was going, the oil metering pump was replaced and the car is still in limp mode. Not receiving any other error codes? Could the ECU need to be replaced, or what else could be causing this? Also wiring to OMP is working properly.
Old Aug 14, 2009 | 10:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If it's anything like the electric OMP / ECU setup on an S5 ('89-'92), when the OMP fails, it'll take the ECU with it. I just saw some pictures recently of fried resistors on an S5 owner's circuit board.
Old Aug 16, 2009 | 07:01 PM
dgeesaman's Avatar
Change the ECU. I have seen the same thing - a combination OMP / ECU failure. Stock ECUs are only like $30.
Dave
Old Aug 17, 2009 | 06:26 PM
Kaosking's Avatar
Thanks for the replies I have gotten my hands on another ECU and it's on the way. Hopefully, my car will finally unlimp-mode itself. What else would cause it to go into limp mode?
Old Aug 17, 2009 | 07:50 PM
Top Down, Boost Up
Limp mode is enabled when key devices like the OMP fail.
Old Aug 17, 2009 | 10:38 PM
gracer7-rx7's Avatar
needs more track time
Did you check the wiring to the OMP? IF there is a problem with the wiring then, it would appear to the ECU that the OMP was still failed and it won't get out of limp mode. Did you read the codes/lights to determine if the error code was related to the OMP after replacing?
Old Aug 28, 2009 | 02:15 PM
Kaosking's Avatar
Thanks to all that replied! I am finally out of limp mode after replacing the OMP and the ECU. Car runs very strong again. On a side note, solely replacing the bad OMP did not fix the limp mode, it wasn't until i also replaced the ECU that the problem went away, thanks again!
Skeese
65
Mar 28, 2017 03:30 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
