need help car driving me mad
Old Aug 12, 2009 | 06:42 PM
babymario1001's Avatar
Angry need help car driving me mad
hello everybody my name is aj and i have 87 tubo II
i rebuilt the motor, mild street port, tc injectors 720cc, and a 255 warlboro fuel pump, new turbo i think t62, external wastegate, and i will be using my stand alone ecu (power fc), yea have a power fc ecu, so no maf sensor.
the problem that i have is that the car needs a little starter fuild to start up but cant hold the idle, but sounds great after reving to about 3000+
anyone run into this issue and have any ideas or a direction that i can go towards, bc i am all out of options.
Last edited by mar3; Aug 13, 2009 at 11:08 PM. Reason: Added text from deletd DUPE thread...
Old Aug 14, 2009 | 12:00 AM
RotaryRocket88's Avatar
Top Down, Boost Up
If it is a recent rebuild, the seals will need time to seat properly. Until then, it is pretty common for it to be hard to start & require a higher idle speed. Adjust the throttle stop slightly, and see if it will idle at ~1K RPM. You should also do a compression test to be sure it isn't absurdly low.
Old Aug 14, 2009 | 12:47 AM
i checked the compression it was good not low at all............i will try to adjust the throttle idle, but sometimes i even have to spray a little of ether to fire up which i dont think has to realy to do with the rebuild and throttle control
Old Aug 14, 2009 | 01:07 AM
shmacklepap's Avatar
FD** Fire Disaster
Low fuel pressure? I had the exact same problem with very low fuel pressure.
Do you have an after market fuel pressure regulator with a gauge?
Old Aug 14, 2009 | 04:53 PM
Rextasee's Avatar
808gxl
thats weird something like low fuel pressure logically would have the opposite effect... or i just dont know nothin!
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
Marty RE
Aug 13, 2015 11:19 AM
