oregon emissions
Old Aug 11, 2009 | 02:15 PM
RotaryBuffalo's Avatar
oregon emissions
so i was wondering how hard it is to pass emission in oregon cuz i got an FC that i need to register and go through emissions. The guy i bought it from put an exhaust on it that looks to be about 2 1/2 with no muffler tips and it has one cat before the y pipe . Is this gonna be able to pass in oregon?
Old Aug 11, 2009 | 04:06 PM
Derekcat's Avatar
Rotary Zealot!
Yes.
But how is the question.
Try running it through DEQ how it is now, and let us know what the readings are if you fail [or if you pass ]
at worst.. You might have to borrow or buy a new cat, run it down to 1/8th tank and put two bottles of isoheet in the tank, and connect the output of the air pump to the cat ext. tube ["Split air pipe"]
Depending on your readings if you fail, is where we switch from using your cat or a different one. [The rest of the procedure is the same]
Old Aug 11, 2009 | 05:01 PM
ok thanks im gonnna try to run through and see if i pass thanks for the info
ls1swap
Jun 3, 2024 03:25 PM
RedBaronII
Sep 20, 2015 11:29 AM
