spark plug clarification/recommendation
Old Aug 10, 2009 | 10:10 PM
anthology1987's Avatar
F#@$ Pistons
FL spark plug clarification/recommendation
i was recommended by an ebay dealer to use 4 trailing plugs instead of 2 ment for leading and 2 ment for trailing. this was after asking him if was really selling 4 BUR9EQ NGK plugs, i thought maybe it was a typo. has anyone heard of this.
im currently using the $100 set from mazda (which was recommended by the person who rebuilt the engine) that i currently have 23K miles on.
Old Aug 11, 2009 | 02:20 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
On a mostly stock NA motor you can run just about any plugs you want.
On a mostly stock Turbo car you want to run the 2XLeading and 2XTrailing or you can use the 4XTrailings
On a wild turbo car you will want to use colder plugs in the Trailing and possible even the leading
The Higher the number the colder the plug and the less change of detonation from a hot plug.
Old Aug 12, 2009 | 06:59 PM
F#@$ Pistons
Question the logic behind spark plugs
thats interesting, as well as something that im willing to try, but do you have a link for the logic behind the differences between leading and trailing spark plugs
Old Aug 12, 2009 | 07:34 PM
2J-Z's Avatar
Also here is a useful link
http://www.youtube.com/watch?v=fiMM2...layer_embedded
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Frox
Feb 27, 2016 11:11 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
